C10 Club Tennessee
WTB: Pedal Studs
My truck doesn't have any at all. So obviously I need both of them.
My zip is 37188 thanks
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
Young Gun wth Fast Inline
Can you give more of a description of what you need? like the studs that go thru the floor for the 67-68 style gas pedal or what? I can probably get you what you need if i know what it is. JT
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!! |
those things are a pain, i prefer to go without the pedal if your talking about the floor mount pedal
I have new GM pedal studs in stock 3.79 each.
Rest in Peace Ed. Thanks for all the good times. Last edited by MOTHERTRUCKERS; 12-04-2004 at 06:27 AM. |
C10 Club Tennessee
I have a 70 stepside. I need the two pedal studs that the gas pedal fits down on.
thanks
its all about the +6 inches
If you have a beater, or an outright POS driver, get the base model plastic throttle pedal and run a couple screws through the flap on the bottom straight through the floor board. A drill with a screw driver bit makes easy work of this, and then dab some black paint on the screw heads...
Done. |
