Old 12-03-2004, 02:01 AM   #1
gregbr
Senoir Member
gregbr's Avatar
Need wiper switch for later tilt column.
Does anyone know where to buy a new wiper switch.....it's a later car type tilt column that has the wiper switch on the column...without delay. I can find the ones with the delay marks just about anywhere. Greg
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4"
70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010
70 GMC Restoration Pictures
http://67-72chevytrucks.com/gallery/...00&ppuser=4424
gregbr is offline   Reply With Quote
Old 12-03-2004, 07:54 AM   #2
68C15
blood type; Retumbo
68C15's Avatar
they are in fact still available from GM & AC Delco. I wouldnt settle for any other brand as it is kind of a pain to replace. I have done quite a few for customers. if they give you a hassle about the application tell them it is for a '92 C2500 without delay.
let me know if you need help with replacement.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 12-04-2004, 11:18 PM   #3
gregbr
Senoir Member
gregbr's Avatar
Thanks, My column is around a 77 model Pontiac, but probably interchangable with many makes/years. The only problem I've had is pulling the wires in & out of the column. Greg
Old 12-05-2004, 10:31 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Do you need the switch its self...or just the lever?
Old 12-05-2004, 07:34 PM   #5
gregbr
Senoir Member
gregbr's Avatar
The switch is made inside the lever.....right. I would perfer to get the complete lever assembly. Any idea on getting out the pivot pins to tighten up the column? Greg
Old 12-05-2004, 08:07 PM   #6
Longhorn Man
no, the lever pulls right off, the switch is in the column.
Old 12-05-2004, 08:22 PM   #7
gregbr
Senoir Member
gregbr's Avatar
I think I understand now....maybe. I need the lever part, everything is OK in the column. If you have the delay switch & lever I would be interested all 3 items. Thanks, Greg
Old 12-06-2004, 12:10 AM   #8
Longhorn Man
might be quicker and cheaper to just go to auto zone or what ever, in the help section. Can't cost much more than 10 bucks....probably less.
Old 12-06-2004, 12:14 AM   #9
gregbr
Senoir Member
gregbr's Avatar
They only carry the ones with delay......about $25. Greg
Old 12-06-2004, 12:38 AM   #10
454_72_4X4
454_72_4X4's Avatar
Just for your info,
Snap-on sells a puller to pull the pivot pins out so you can tighten up the column. That's about the only way to get them out without destroying things. I think it's around $15, (but it's been a few years since I bought mine). I might be able to get a part # if it's marked. I think you'll also need a torx socket to tighten up the bolts that are loose.
I've probably got the lever you need too. I'll take a look tommorrow.
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 12-07-2004, 05:40 AM   #11
gregbr
Senoir Member
gregbr's Avatar
Correct on the torx socket. I also found a simple tool made by Lisle for pulling the pins that NAPA can order, nobody here stocks it. I managed to get the stuck pin out, using a 8/32 screw, 8/32 nut, large washer and a socket bigger than the pin. It came right out. I definitly would NOT use the dent puller again. Greg
