12-03-2004, 08:15 AM | #1 |
Vortec in the works
Nice Find
Picked up a parts truck and found a little gem burried in the leaves on the floor board
68? It's all figured out untill you get it apart. Is it Sunday yet??? 68 Project 68 SWB frame off/98 Vortec with stock FI/power everything. 95 ECLB 2500 with 346,000 on the clock(the original HD) 99 Lesabre-wifes ride 08 Crew Cab LTZ-All Mine 89 SWB 5/7 drop-Son's first ride. |
12-03-2004, 09:24 AM | #2 |
Interesting. Air Press guage, huh? That's one of my 67-72 Chevy knowledge gaps. Please, educate me on their original use.
And do you think that gauge lens will clean up well enough to use? I see the air hose fitting. Any way to easily check if the guage functions? And was that parts truck PO into brake cooling?
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
12-03-2004, 09:33 AM | #3 |
Vortec in the works
I'm not that educated on that subject either, I know they were used on the larger trucks,I'mm going to clean up this weekend.
It's amazing what some people will do with a torch and welder
12-03-2004, 09:58 AM | #4 |
its just $$$$$
i'm not positive, but i think they were used on trucks with air brakes.
12-03-2004, 10:26 AM | #5 |
So your the one who bought that truck huh? I think i hear the Miami vice theme song playing. :p
12-03-2004, 10:30 AM | #6 |
Vortec in the works
I'm actully the second one to buy it
12-03-2004, 10:54 AM | #7 | |
12-03-2004, 11:00 AM | #8 |
No...that air pressure gauge monitored the remote pressure sensors that were located inside each tire. The total amount of pressure for all tires was indicated on the needle or gauge. Any takers? LOL.
Alex 1971 Lil' Red 350 SBC 700R4 |
12-03-2004, 11:16 AM | #9 | |
Vortec in the works
12-03-2004, 11:45 AM | #10 |
Yes the air gauge is for the big trucks (C50,C60,C70) with air brakes. Notice that the notch for the steering column is not cut out all the way. This can be trimed to fit. My dad has a few dump trucks he uses and a few parts trucks. One of them is a 70 C60 with air brakes and a 366 big block. It has the air gauge and a huge engine driven compressor. The gauge would be cool in a air ride C10. The compressor sits above the engine on the pass side and would not fit under the hood of a pickup but it could be moved to the side of the engine. I got a vacuum gauge out of another C60 427 truck we had to bad neither truck had a tach or speed warning. Other cool and more common dump truck paarts are radio delete plate, and cowl w/o antena hole. Some day after I get my 67 C10 swb fleetside finished I would like to build one and use that tall deck 427. Thats a cool engine that don't fit well in cars but can be fitted into a pickup.
12-03-2004, 03:26 PM | #11 |
If only one could find a guage lens that combines marks for a tach and the air pressure guage. That would be the set up for a manual trans, air-bagged C10. Does anybody custom mark 67-72 lenses with such a need?
Texas 68, post more pics once you have it cleaned up.
12-03-2004, 04:29 PM | #12 |
4x4poet thats what I was thinking. A person could cut and splice the air gauge lens and a tach lens together. I've seen this done with a vacuum gauge and you could not tell. Somewhere somebody has a stack of these NOS thinking no one would want one for a pickup.
12-03-2004, 07:44 PM | #13 |
On the road
I picked up one of those dashes one time with a tach and air gauge out of a big truck. I don't know what happened to the lense but I think I still have the air gauge somewhere. I used the tach setup in a truck I had at the time but I did not use the lense or air gauge. I bought a new lense for the tach. It would be cool if you had bags.
Mike Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos 72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works. My new build thread "Castro" https://67-72chevytrucks.com/vboard/...d.php?t=820934 My old build thread, the blue truck http://67-72chevytrucks.com/vboard/s...d.php?t=271489 www.louisianaclassictruckclub.com |
12-03-2004, 07:51 PM | #14 |
Maybe you could sell it to someone that uses an air suspension. They could use it to monitor air pressure. That would be cool and stock looking at the same time.
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd |
12-03-2004, 11:11 PM | #15 |
Roadtrip!
Kind of a dark pic, but this is what you are referring to. (not for sale)
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
12-03-2004, 11:30 PM | #16 |
tms, that pic and your sig line proves that you definately have too much stuff.
12-03-2004, 11:36 PM | #17 |
its all about the +6 inches
I found one in a junk yard here a few years ago, cleaned it up and installed a new bezel, I think I sold it for 90 bucks or so on here...no tach, just air pressure. Got it off a 70 C/50 tandem axle bobtail truck. (small gas powered semi)
12-03-2004, 11:36 PM | #18 | |
Happy to be here
12-03-2004, 11:46 PM | #19 |
Roadtrip!
4x4 poet, I just like to try and have "different" things. I have only seen one of these in person before. Blah, blah, blah.... I can't cover myself. You are right, too much stuff...
Not to rob the thread, but this one is pretty unique also.
12-04-2004, 01:23 AM | #20 |
My other Love
man that thing red lines really early!
Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
12-04-2004, 01:29 AM | #21 |
What did that tach come out of originally? It looks about right for a V-6.
V-6....only GMC Trucks have it! 62 GMC W5000 NAPCO-V6 65 GMC 2500 NAPCO Panel-V6 66 GMC 1000-V6 66 GMC 1500-V6 67 GMC K1500-SBC (originally a KM-V6) 68 GMC C1500-V6 68 GMC C1500-V6 68 GMC Suburban C2500 70 Chevy K20-SBC 71 Chevy C30 Longhorn-SBC 72 GMC Suburban C1500-BBC 72 Chevy C10-SBC 72 GMC C5500-ToroFlow Diesel |
12-04-2004, 01:42 AM | #22 | |
12-04-2004, 01:45 AM | #23 | |
12-04-2004, 02:19 AM | #24 |
My other Love
they didnt have diesels, back then, I think its out of a 305 v6
12-04-2004, 02:21 AM | #25 |
My other Love
wait a second, that guage on the very left looks odd to me, that doesnt look like an ammeter?
