Rusty Rockerfeller
![]() Join Date: May 2003
Just in case what is the correct auto trans
what is the correct length automatic trans for a 70 with a big block?Im thinking with a turbo 400.Thanks
Turbo 400 seems to be the right choice...but don't you mean what is the correct "DriveShaft" length? I've got a similar issue going on as I have a 350 SBC and am installing a 700r4, which the drive shaft will have to be shortened. I plan on hooking it all up and measuring and then have it cut. Hope this helps.
Alex 1971 Lil' Red 350 SBC 700R4 |
Rusty Rockerfeller
i was thinking what will work with the auto crossmember
Lovin' Life in Miss.!
Chevydude, call your driveshaft shop up and ask them how to measure it. I shortened my 2 piece and they wanted from center of carrier bearing to tip of output shaft. Your shop might want differant.
Bigunde, can't say for your xmember question.
The truck... you hear that? No really, you did hear that?!!! |
Rusty Rockerfeller
we use advanced driveline here and they tell me to measure from the end of the tail shaft to the yoke on the rear,but i know people do it different.
Thanks Chicken Wing. I have friends at the Drive Shaft shop and they are coming out to the house when the Engine and Tranny are setting in place. They want to measure themselves.
Rusty Rockerfeller
i guess what im asking is do i need a long or short shaft tranny to work with a factory automatic crossmember?
Either. They use the same mount.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
Rusty Rockerfeller
,its adjustable that much?.i know there is usually a few inches different.
