Old 12-03-2004, 12:15 PM   #1
BobS
BobS's Avatar
Hand throttle
Does anyone know how and where the cable for a 67-70 hand throttle is mounted as it passes through the firewall?
Bob
V-6....only GMC Trucks have it!
62 GMC W5000 NAPCO-V6
65 GMC 2500 NAPCO Panel-V6
66 GMC 1000-V6
66 GMC 1500-V6
67 GMC K1500-SBC (originally a KM-V6)
68 GMC C1500-V6
68 GMC C1500-V6
68 GMC Suburban C2500
70 Chevy K20-SBC
71 Chevy C30 Longhorn-SBC
72 GMC Suburban C1500-BBC
72 Chevy C10-SBC
72 GMC C5500-ToroFlow Diesel
BobS is offline   Reply With Quote
Old 12-03-2004, 12:25 PM   #2
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
what is this hand throttle stuff all about? i saw a bezel with it but dont understand.
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 12-03-2004, 12:29 PM   #3
CPNE
Resident Curmudgeon
CPNE's Avatar
Bob
Sorry no pic, but it attached to a bracket that is clamped onto the pedal rod on the engine side of the firewall.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 12-03-2004, 12:33 PM   #4
CPNE
Resident Curmudgeon
CPNE's Avatar
It is a way of setting and maintaining a higher engine rpm without having to put your foot on the pedal. The cable/knob mechanism as detents in it to allow for several setting that can be fine-tuned to some degree.
Why, you ask? To operate PTO's and/or engine driven hydraulics without having to be in the cab or in instances where you can't conveniently do it via the foot pedal. Think of applications like plows, winches, dump bodies, etc. It is not a poor man's cruise control
Old 12-03-2004, 12:36 PM   #5
BobS
BobS's Avatar
I've got the piece that bolts to the rod on the engine side, it seems like there should be some kind of clamp that secures the cable to the firewall to eliminate slop?
Hand throttles were an option, although mostly used on the larger trucks, to increase idle speeds or operate a PTO.
Bob
66 GMC 1000-V6
66 GMC 1500-V6
68 GMC C1500-V6
68 GMC C1500-V6
70 Chevy K20-SBC
72 Chevy C10-SBC
Old 12-03-2004, 12:42 PM   #6
67ChevyC10Stepside
oh.....i didnt know if it was for when your foot got tired or what lol.
Old 12-03-2004, 03:45 PM   #7
Yukon Jack
Post Whore
Yukon Jack's Avatar
Like stated above, the hand throttle is commonly used to keep rpm's up while using a PTO accessory.
Here are two pics showing how it is attached to the throttle arm.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 12-03-2004, 05:02 PM   #8
Oakley
Junior Member
Oakley's Avatar
I have a 71 blazer 4X4 with the throttle option but mine does not go thru the firewall mine attaches to the gas pedal itself.
Oakley is offline   Reply With Quote
Old 12-03-2004, 05:06 PM   #9
dubie
dubie's Avatar
Mine didn't even go thru the firewall. It attached right ot a bracket on the pedal. You would pull it out a couple clicks and it would pull the pedal down to where you wanted it. I took it off and sold it to a former board member to run higher rpm's for his A/C in the desert. Sure wish I wouldn't have sold it now tho It was a great Redneck cruise control :F
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 12-03-2004, 06:18 PM   #10
CPNE
Resident Curmudgeon
CPNE's Avatar
Taht is the 71/72 version. Change in design due to change in accellerator linkage from rod to cable.
Old 12-03-2004, 08:56 PM   #11
BobS
BobS's Avatar
Yukon Jack,
Do you have a pic or even a description of the other side of the firewall where the cable goes through? Does it just come through the firewall or is there some kind of clamp or grommet or something else?
Bob
66 GMC 1000-V6
66 GMC 1500-V6
68 GMC C1500-V6
68 GMC C1500-V6
70 Chevy K20-SBC
72 Chevy C10-SBC
Old 12-03-2004, 09:03 PM   #12
chevy71super
My dad's 72 had one. Ranch truck, we used it feeding cattle. Put the truck in 4 wheel low, 1st gear, and pulled the knob out a few clicks. Jumped in back and started throwing hay to the cows. With over a ton of hay in the back that thing would idle right along through almost anything. Snow or no snow. (Ground was usually frozen solid.) When it got real bad we would chain it up. The good old days . . .
chevy71super is offline   Reply With Quote
Old 12-03-2004, 09:24 PM   #13
Bob Moore
Hand Throttle
Location through the firewall.
If you look close from the engine side you will see a dimple or nipple ( i can't remember which on the engine side) - that is the location to drill a very small hole to feed the cable through. The factory had a spring cable clamp to secure the outer housing. The location of the dimple is roughly at the top of throttle arm and slightly centered from the throttle arm. Another way to find the location from the interior is to look for a knock-out in the firewall padding (approximately 3/4inch) - the dimple is behind it. Remove the knock-out and you should see the dimple.
Hope this helps - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 12-03-2004, 09:32 PM   #14
teamharvey
teamharvey's Avatar
So that is what this bracket is/was for ? I would like to get rid of mine since it is useless except that it holds my throttle assembly in place. Is there another bracket I could use /
thanks,
bret
71 Custom 20 Deluxe..soon to be SWB 1/2 ton
1 incredible wife
2 great kids
teamharvey is offline   Reply With Quote
Old 12-03-2004, 09:40 PM   #15
Bob Moore
what is bracket
That is a 71-72 throttle bracket - the cable style. The T-400 kick-down switch mounted there and was activated when the arm came back as the trottle was stepped on. The hand throttle for 71 & 72 also mounted to the bracket on the upper corner - I believe.
vac, 454, T400
more to follow
Old 12-03-2004, 10:49 PM   #16
Solver
Solver's Avatar
My green 67 came factory with a hand throttle but I have never checked underneath to see how it is hooked up.
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 12-03-2004, 11:38 PM   #17
Yukon Jack
Post Whore
Yukon Jack's Avatar
BobS, like Bob Moore stated, there is a metal clamp that goes through the hole in the firewall to secure the cable. No grommet at least on mine.
Old 12-04-2004, 01:16 AM   #18
BobS
BobS's Avatar
Looks like all I'm missing is a clamp then, anyone know where to find one?
Bob
66 GMC 1000-V6
66 GMC 1500-V6
68 GMC C1500-V6
68 GMC C1500-V6
70 Chevy K20-SBC
72 Chevy C10-SBC
