Old 12-03-2004, 07:24 PM   #1
Gator70
Gator70's Avatar
Lightbulb Cant decide on lift height
Im needin to put a lift in my 70 K15 and I cant decide on how much to lift it. It needs new springs so I figured this would kill two birds etc...
I dont want a monster but something that will look tough.
Im considering a superlift 2.5" or 4".
Can you guys post some pics of your lifts so I can get some ideas. I dont think that I'll go any bigger than 33" tires, probably stay with 31's. Im actually running 16" wheels from my 98 on it with the standard Z71 size of 265/75R16.
Any help would be fantastic
Thanks.
Gator
1970 GMC K15 - Canadian built
2nd Owner truck 68k miles
2014 Denali 1500 6.2L
Gator70 is offline   Reply With Quote
Old 12-03-2004, 07:47 PM   #2
Gator70
Gator70's Avatar
Guess I should have put some more info in. Any problems driveline angles etc with 4" would I be wasting money on a 2.5" when I should have gone 4. Brakeline extensions, steering stabilizer add-ons ????
Old 12-03-2004, 07:57 PM   #3
vtblazer
vtblazer's Avatar
Lift
You can run 33's with a 2" lift very comfortably but I like 33's with a 4" lift myself.
All these trucks should have steering stabalizer's on them, they did from the factory.
With a 4" you'll want a dropped arm and a longer drive shaft's and of course will need longer shocks.
Someone will get on and tell you, "it all depends on what your doing with it" and that's a fair question. What are you expecting?
vtblazer is offline   Reply With Quote
Old 12-03-2004, 08:07 PM   #4
vtblazer
vtblazer's Avatar
Lift
My 70 has a 2" lift on it.
Here it's sitting next to the blazer that has a 4" spring lift.
Old 12-03-2004, 08:35 PM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Look at the pics in the link in my signature.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 12-03-2004, 10:18 PM   #6
Mudder
Mudder's Avatar
Myself, if youre gonna go to all the trouble to put a lift kit on you may as well go with a 4 inch. A raised steering arm. Re adjust you brake lines and maybe lower your TC, you'll be good to go.
Mudder is offline   Reply With Quote
Old 12-03-2004, 11:13 PM   #7
4x4Poet
By chance, can you post a pic of your rig? Either lift should have extended brake hoses. I'm about to put extended SS braided hoses on my K10 because the orig rubber hoses need replacement and I figured the next owner would appreciate the longer hoses in case he wants to lift it. Mine looked like they could give out any moment. One had a chunk of outer sheath missing. So the hoses dilapidated condition was an excuse to put on longer SS hoses regardless of no lift yet. Steering stabilizers help slow down bump steer. Use a dropped pitman arm to match the chosen lift and you'll have less need for a stabilizer because the drag link will stay faily close to level.
vtblazer, nice rig and great stance.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 12-03-2004, 11:42 PM   #8
Yukon Jack
Post Whore
Yukon Jack's Avatar
The first pic you see here is my 69 with 4" of lift. All the pics have the same 35" tires on the truck.
Next is when I added a little more lift to about 6" of lift.
And here it is with about 10"
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 12-04-2004, 08:00 AM   #9
see ten
WTB this ad
see ten's Avatar
Have the man at the parts counter pull you out a brake line for a 2wd pickup of the same year. They are much longer than the 4wd lines and can be bought for cheap!
see ten is offline   Reply With Quote
Old 12-04-2004, 12:01 PM   #10
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Exactly! Personally, I prefer just enough lift to fit the tires you will be running. For 33s, that means 2" - 2.5". That's the combo I have had for several years, and the only thing I needed was longer shocks; I didn't change brake lines, pitman arm, driveshaft or anything else. In fact, the reason I put the Softride springs on was my original fronts were sagging.
4" kits are very popular though, so it really depends on your preference.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 12-04-2004, 02:26 PM   #11
4x4Poet
Great tip. Thanks. I'll keep it in mind. Unfortunately, I favor SS braided brake lines with teflon inners for stiff braking. Hurts my wallet every time.
Old 12-04-2004, 03:26 PM   #12
Gator70
Gator70's Avatar
Thanks for the input guys. Ill try to muster up a pic of my truck. I basically just want the lift for a tougher stance. This truck will never see any serious off roading. It was purchased new by my Grandad in the fall of '69 and only has 58K miles. This will be my keeper truck.
Old 12-04-2004, 04:13 PM   #13
4x4Poet
Originally Posted by Gator70
...I basically just want the lift for a tougher stance. This truck will never see any serious off roading....
Sounds like 2.5 inches for sure. Consider that a truck used primarily on the highway will get better mileage with less lift due to the lower stance that keeps wind blockage to a minimum. The lower the better for towing, too. And tires drive the lift height. No rough 4 wheeling means no need for big tires which means a mild lift will do.
Old 12-04-2004, 07:24 PM   #14
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I have the p/n for longer brake lines I put on my 71. Got them from autozone, I'll post them when I find what I did with the packages. Dean has them also on both his 3/4 tons.
Old 12-05-2004, 08:44 AM   #15
bodazpa
bodazpa's Avatar
If your gonna take the time and take the truck apart, go with the 4in. I have 4 on my 71 with 33`s. The only thing I had to change is the drop steering arm, and shocks(but most kits come with shocks anyway). If your going with 33in tires your not gonna notice any less gas or performance with the 4 as comparede to the 2.5. Here is a pic of my 71 with 4 and 33`s....Good luck
71 chevy 4x4 ,np205 transfer case, 3 speed tranny, sjs 283, 4in suspension lift, and 71 hugger orange paint,33x12.5 parnelli jones on 15x10 m/t classicII, cowl hood,new bed painted, linex liner. Truck has been completed since 2005....
2003 Chevy Avalanche Z71, on 6in super lift w/ 35in tires
RNG4x4 aka the "Redneck Roller"
words to live by "If it fits, it fits"
"friends help you move, real friends help you move bodies..."
Sponsored by "Kick Ass Kustom"
bodazpa is offline   Reply With Quote
Old 12-05-2004, 08:58 AM   #16
vtblazer
vtblazer's Avatar
Now there's your "tougher stance"
Nice truck bodazpa.
Old 12-05-2004, 09:02 AM   #17
bodazpa
bodazpa's Avatar
Thanks, hay vt did you ever do any thing with the shortbed 4by you bought...
Old 12-05-2004, 03:07 PM   #18
4x4Poet
That is one fine truck, bodazpa!
And I say that not liking orange paint colors.
Old 12-05-2004, 04:00 PM   #19
Kurt L
Kurt L's Avatar
call skyjacker or rancho,trailblazer,i think that's it.i had a 75 blazer with 8'' of lift bought everything from skyjacker. my kit cost rite at $2,000 with everything.shocks springs,brake lines,steering stablizer,steering arm.they come with all your blocks,ubolts,
etc.
Kurt L is offline   Reply With Quote
Old 12-05-2004, 09:46 PM   #20
RainFade
RainFade's Avatar
I notice the common wisdom seems to be that with 4" of lift you MUST do the steering arm.
Years ago a buddy lifted his mid 70's 3/4 ton chevy 4" and installed the arm and the bump steer was flat out dangerous !
He took the drop arm back off re installed the stock arm and it handled great no bump steer.
With this in mind when I did my 4" I decided to test drive w/o the arm first (kit came with the arm) and what do you know no bump steer... am I a disaster waiting to happen ? lucky, or what ?
71 K20 350/350/205, dealer air, 4" lift, Flowtech,Edel 1406 on 2101, procomp HEI,4.10's, 33x12.50x16.5 BFG MT's on slots. 4 wheel disc brakes.
My lame K20 page
My lame Eaton disc brake page
RainFade is offline   Reply With Quote
Old 12-05-2004, 10:27 PM   #21
Mudder
Mudder's Avatar
I have a four inch raised and I can take my hands off the wheel going down straight highway. I've never had any problems with bump steer.
Old 12-06-2004, 01:23 PM   #22
Yukon Jack
Post Whore
Yukon Jack's Avatar
My 69 was without the dropped drag link for a few months and definitely needed it. Much nicer to drive with it.
Old 12-06-2004, 06:07 PM   #23
Gator70
Gator70's Avatar
Bodazpa nailed it. That is a very nice ride. especially with the cowl hood. Im on the path to greatness now. I appreciate all of your guys' input. It helps when someone has done it before and knows the ins and outs of the task.
Old 12-06-2004, 07:41 PM   #24
bodazpa
bodazpa's Avatar
glad i could help.........good luck.....john
Old 12-07-2004, 05:25 PM   #25
griesel72
griesel72's Avatar
Thanks bodazpa, i now have a new background for my computer.
1969 K10 Custom 10
1997 Z71
2006 Volkswagen Jetta TDI
2006 King Ranch
1980 Wife
griesel72 is offline   Reply With Quote
