Anybody got a junk body or cab for parts?
I need a couple of pieces off a junk body or cab.
1) passenger side, top, door hinge, nut plate. It's the piece rattling around inside the door post where the bolts thread into. 2) passenger side, frount, inboard seat nut plates. In the floor board, where the seats mount 2 nuts are welded to the tub crossmember. One of mine is stripped so I figured I'd replace both. If anybody has an old, junk cab or body laying around they'd be willing to torch these pieces off of, Let me know what you'd need for them. |
Parts
I am cutting a cab up on monday i will see what i have .
Thanks C-1072
I really appreciate it. If you aren't clear about what I need, I can send you a picture or try to clearify. Sometimes my descriptions aren't the greatest.
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I may have the nut plate let me look around you can have it if I find em.... P.m. me you addy and I get them shipped.
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
PROJECT 7DEUCE
No problem.. I would like to see what you guys do to get the plate in there though as I have the same thing I need to do to mine..
repair
Tim will do this one.
He says 'I'm going to cut a #$@#$ hole under the dash, work the nut plate into the post, and weld the $%!@$# hole back up. Then, I'm going to let you paint the #@$@#$ patch. It will be a while before he gets around to doing it though. We are moving in a few days and with Christmas, we have a full plate. Thank you so much for the part. |
