Old 12-04-2004, 12:05 AM   #1
N2TRUX
Happy to be here
N2TRUX's Avatar
Air bag diagrams
I have seen some pretty nice air bag diagrams posted her recently in various threads. Lets try to get them all on one thread. Be sure to post a link to where they came from in case there is more info available on the linked site.
Here are a couple I have found-
From www.fullsizechevy.com
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-04-2004, 12:07 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
2.........
Old 12-04-2004, 12:08 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
3.........
Old 12-04-2004, 12:08 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
4.........
Old 12-04-2004, 12:09 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
5..........
Old 12-04-2004, 12:09 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
6.........
Old 12-04-2004, 05:50 PM   #7
flatblackclassic
I don't have any but thanks for posting those!
flatblackclassic is offline   Reply With Quote
Old 12-05-2004, 11:54 AM   #8
hotrodhomi
hotrodhomi's Avatar
STICKY or FAQ
hotrodhomi is offline   Reply With Quote
Old 12-05-2004, 05:02 PM   #9
PRUNEDA
'87
PRUNEDA's Avatar
real helpful pos n2trux. i'm with hotrod, it would be a good idea to sticky it.
PRUNEDA is offline   Reply With Quote
Old 12-05-2004, 09:43 PM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
More.........
Old 12-05-2004, 09:43 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
Again.........
[IMG]http://www.*****************/products/airmanagement/how-to/8valve.gif[/IMG]
Old 12-12-2004, 12:43 PM   #12
hotrodhomi
hotrodhomi's Avatar
TTT.. very helpful
Old 12-21-2004, 05:53 PM   #13
jeffnstef
jeffnstef's Avatar
Switches...
I understand the air diagram and the wireing diagram, But how do you regulate the pressure in the bags ? Is this done manually each time that you fill the bags keeping an eye on the pressure gauge ?
Or is there a way to hit one switch and have all the bags inflate to a predetermined pressure and another switch to dump ? I have seen the pictures of controllers that have 8 switches and that seems a little complex !
jeffnstef is offline   Reply With Quote
Old 12-25-2004, 11:56 PM   #14
r0lf-
Hotwheels?
r0lf-'s Avatar
Well, there isnt 8 switches, for an independant wheel system like these diagrams show there is only 4. Up/Down for each wheel. You could rig something like you are talking about, but it would require lots of sensors and elecrical work.
Getting 4 wheels at a set PSI isnt hard. Just watch the gauge, air up or down and drive.
1978 Money Pit - CUSTOM DELUXE!!!!
r0lf- is offline   Reply With Quote
Old 12-26-2004, 10:16 AM   #15
N2TRUX
Happy to be here
N2TRUX's Avatar
Yes, if you air it out every time you park, then you will have to set it to ride height every time you roll. Most of the mechanical gauges have dual needles so you only need two gauges on a way way system though. Digital gauges show the air pressure at each corner.
Or is there a way to hit one switch and have all the bags inflate to a predetermined pressure and another switch to dump ? ...
Yes you can wire an extra switch to raise or dump your sytem. You will have to have a seperate set of relays to do this though. It would require 4 per function, or one per function if you added diodes in the circuit.
It won't go to a predetermined pressure unless you put a seperate pressure regulator in that circuit though.
Here's a pic of the control panel on my 77. The switch in the center is used to dump the system.....
Old 02-05-2005, 10:07 PM   #16
el curioso
el curioso's Avatar
heres a good link on how to do a engine driven commpressor
http://207.97.200.166/manuals/27361.pdf
el curioso is offline   Reply With Quote
