Old 12-04-2004, 01:01 AM   #1
67cst
i love summertime
67cst's Avatar
dad's 72 is poping and farting
need help here guys, we think its a carb problem but just thought id ask the experts for help, my dad just bought a beater 72 chevy 3/4 4x4, 350/th350..he bought it without hearing it run because it didnt have a carb on it, we plan on tearing it apart anyways but thought it would be nice to take it for a spin and make sure that everything works first. so whats happening is we put an old quadrajet on it just to fire it up and it is timed, and fires up nice and idles great but when you go for a blast it backfires out the carb, if you acelerate slow it isnt as bad but if you punch it a bit it runs like $hit....any suggestions? we figure its the cruddy old carb but maybe someone else has an idea
thanks, Derek
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 12-04-2004, 01:18 AM   #2
Hooter
My other Love
Hooter's Avatar
sounds like a classic case of having a couple of lobes worn out on the camshaft which, as you know is extremely common on a smallblock chevy, my 77 used to run the exact same way till i threw a new cam into it, 4 lobes were almost completely rounded off
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 12-04-2004, 01:40 AM   #3
72 CustomCamper
huh ???
72 CustomCamper's Avatar
My 402 did that. I found out it had a bent push rod and weak valve springs. Try doing a compression test. Couldn't hurt at least...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 12-04-2004, 02:36 AM   #4
jimfulco
Old, bad gas will do that sometimes. It will coat the spark plug porcelain with a conductive film that will cause misfiring, especially under load.
jimfulco is offline   Reply With Quote
Old 12-04-2004, 02:46 AM   #5
67cst
i love summertime
67cst's Avatar
jim-never thought about the old gas, it has new plugs and wires but ill pass it on- im not sure if he put new gas in it or not yet, also the compression test is a good idea
thanks guys
Old 12-04-2004, 04:09 AM   #6
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Sounds like it could have a dried out accelerator pump in the carb.Q-jets aren't the best carb to leave setting around.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 12-04-2004, 06:56 AM   #7
OhioDan
OhioDan's Avatar
Question
Sticking intake valve? Weak valve spring?
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 12-04-2004, 02:42 PM   #8
johnje
johnje's Avatar
I just went through that. Truck hadn't run in many years, when I got it started, it backfired out the carb quite a bit. I had several stuck valves and bent pushrods. I can't believe the truck even ran! I just had the heads cleaned up and checked at a machine shop, new springs installed. I'm cleaning up the rocker arm assemblies, should be much better when I get it back together. (Oh yeah, and new pushrods.)
John
'67 M37B1
'67 Galaxie Convertible
'67 GMC Truck
johnje is offline   Reply With Quote
