Captain Ed
Need - Rear end housing
Need a 67-72 trailing arm rear end housing. Internals unimportant. I don't need axles or anything, JUST the housing. I want to sandblast it, paint it and fill it with my own internals. I'm in the north-central part of Kentucky.
![]() Join Date: Dec 1999
I have a rearend how close are you to Cumberland Gap, KY. ?
Captain Ed
2.5 hours. I just moved from there 17 month ago.
![]() Join Date: May 2002
Be sure you know what you need--rear housings are not all same width
Stepsides look like real trucks! Smitty ![]() |
#5 | |
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
Captain Ed
I have a '72 rear end in it now. I thought all the 67-72 1/2 ton were the same width. I will be reusing the axles from my rear end unless the one I get has 5 lug axles and is a different width than mine.
I suspected that was the case--there are at least two, perhaps three widths? If you have a '72 rear now?, you need a '71 or '72 which are 5-lug. Also, is it a coil or leaf spring rear?
70 modles are 1/2 wider that 67-69 and 71-72 Its one of those one year things GM is good for.
Captain Ed
Coil spring/trailing arms.
Believe Bisquik is giving you the straight scoop on this...........
Captain Ed
Mine measures 65 inches between the backs of the wheels (mounting surfaces). The torque thrust II's make it easy to measure! I could go a little narrower but not any wider. I already had to roll my fender lips in.
