Old 12-04-2004, 10:19 AM   #1
DTerry
'70 GMC C-25 LWB
DTerry's Avatar
lowering
I plan on lowering my 1970 c20 with leafs and i want to know how much it would lower the rear if I did a flip kit. Also how much would i have to lower the front to get the truck level.
DTerry is offline   Reply With Quote
Old 12-07-2004, 09:23 PM   #2
corn
A flip kit will usually get you @ 5" so I guess a set of 3" springs or spindles in the front...
corn is offline   Reply With Quote
Old 12-09-2004, 10:45 PM   #3
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Yep, get a flip kit for the rear. Then get some drop spindles for the front. If the front isn't low enough cut 1/2 coil out. If it's still not low enough, cut another 1/2 coil out.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 12-09-2004, 11:13 PM   #4
Shev
Head Peon
Shev's Avatar
Don't cut coils...if it's not right buy dropped coils...
'72 Suburban, factory tilt, tach, front & rear AC, front & rear disc brakes, 383/700-R4
Shev is offline   Reply With Quote
Old 12-09-2004, 11:14 PM   #5
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Right, then buy drop coils to lower to your liking. I meant.
Old 12-09-2004, 11:36 PM   #6
Slammed67
Progress = 0%
Slammed67's Avatar
Well, if cutting coils is wrong, then I don't wanna be right
I have cut coils (1 coil) along with drop spindles in two of my cars and they both ride great. It's best to cut one full coil so that the spring will sit in the spring pocket correctly. Also, if you do cut them, I'd recommend using a Saw-Zall or a cut-off wheel and not a torch. Many people run cut coils, and although that doesn't make it "right", doing it can provide good results. What have you got to lose? Might as well give it a try. If you don't like it, simply buy some drop springs.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 12-10-2004, 09:09 AM   #7
SCOTI
SCOTI's Avatar
Cutting coils is fine as long as you don't go overboard. 1 coil is typically worth about 2" of drop depending on the age/condition of the coil being cut.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
