Old 12-04-2004, 04:45 PM   #1
duno
Talking blazer frame swap help
can i use this frame to make my 72 blazer 2wd
the new frame is from a 1977 chevy shorth bed
do i need to do a lot modifications, this truck is on a auto auctions, so i need help from you guys that may know if the body of the blazer will fit on it.
or what do i need to custom.
thanks guys for your help
this are the pictures
http://images.copart.com/website/dat...0247644_5X.JPG
http://images.copart.com/website/dat...0247644_1X.JPG
http://images.copart.com/website/dat...0247644_2X.JPG
http://images.copart.com/website/dat...0247644_3X.JPG
duno is offline   Reply With Quote
Old 12-04-2004, 05:14 PM   #2
tim_and_bobbi_blazer
Frame
I believe it will be much easier to convert a 69-72 4x4 frame to 2x4 than it will be to use a 73 and later frame. The last one Tim did required a couple of holes to be drilled and every thing else went pretty smooth. You'd need the 2x4 parts from another truck.
For starters, you may want to check wheel base. I believe 69-72 Blazers are shorter than 67-72 SWB trucks. I haven't measured 73 and later pickup frames, but I'm thinking your Blazer will be shorter than them as well.
If that works out, you might want to check the body mount location and types. You may need the ones off your old Blazer frame to mount to the late model frame if the wheel base turns out ok.
Finally, there's been a lot of discussion here in the past on this subject. You may want to read back though the archive. If memory servers, the general opinion is 'don't do it'. Just my $.02
Thank you
Bobbi
See my Blazer Restro Pictures HERE
tim_and_bobbi_blazer is offline   Reply With Quote
Old 12-04-2004, 05:15 PM   #3
4bynut
4bynut's Avatar
DUNO - The short bed truck frame is longer than your blazer frame. And the body probably will need a body lift under it because of the conture of the frame even if it was shortened. It would be best if you can find a actual 2WD blazer frame 69-72. I know a few guys have converted their existing frame. Some convert the rear to trailing arms, but you could leave the leaf spring setup. Hope this helps. Jason
4bynut is offline   Reply With Quote
Old 12-06-2004, 06:10 PM   #4
chevyal71
chevyal71's Avatar
I don't know were you are but I have a spotless 72 blazer 2w/d rolling frame w/disc brakes from NC now in NY for $500. You might have to take the rusty body sitting on it too though. The nice body is now on my 4w/d. I also run from here to NC with a trailer if you might be on the way
chevyal71 is offline   Reply With Quote
Old 12-06-2004, 06:11 PM   #5
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
WOW, U SUCK, J/K , I WISH YOU WERE CLOSER
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 12-06-2004, 06:28 PM   #6
chevyal71
chevyal71's Avatar
I'll meet you near Charolette with it if you want. Going that way anyway
Old 12-06-2004, 06:32 PM   #7
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Talking Trade
ASSUMING U MEANT ME, THANKS BUT I'M ALL CASHED OUT, YOU DON'T
NEED A SWB DAILY DRIVER DO YA? JUST NEEDS A HEADGASKET, J/K
Old 12-08-2004, 07:02 PM   #8
vtblazer
vtblazer's Avatar
2wd Blazer Frame
If duno doesn't want it, would you send me a pm with the details? Interested.
Where in NY are you located?
vtblazer is offline   Reply With Quote
Old 12-08-2004, 07:22 PM   #9
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Originally Posted by vtblazer
Interested
FIGURES
Old 12-08-2004, 09:00 PM   #10
vtblazer
vtblazer's Avatar
Originally Posted by LUV2XCLR8
FIGURES
yer killin' me smalls... :p
Old 12-08-2004, 09:07 PM   #11
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
SORRY KURT, JUST WISHING IT WAS ME
Old 12-09-2004, 04:46 PM   #12
chevyal71
chevyal71's Avatar
some details on that swb daily driver please.
Old 12-09-2004, 04:50 PM   #13
vtblazer
vtblazer's Avatar
Any news yet?
Just checking, thanks.
Old 12-10-2004, 11:00 PM   #14
blazunfool
I have an extra 2wd blazer frame, has trailing arms on it. Maryland
72 2wd Blazer 305TBI/700r4., 69 C10 SWB 400SB TPI, 400trans, Step side ., 72 4WD Blazer 350 TBI, 350 serp. drive & "Old Air" ., 94 Camaro Z28 LT1., 94 Grand Cherokee V8, 95 Grand Cherokee 6cyl.
blazunfool is offline   Reply With Quote
