#1 OU Soonerfan
broken u bolts help!
70 Chevy 3/4t
It would be best to look at your cups holding your springs onto the trailing arms at the same time and replace them as well while things are apart. GM offers the cups and U bolts.
Be sure to jack the vehicle up by the frame to relieve all tension from the springs. Take your time and be careful. And before long you will be ![]()
Find a job you love and you'll never have to work a day in your life. 1998 Yamaha V-Star 650 1970 Chevy 3/4t, I6 (rebuilt), 4 speed Kokomo,IN |
#1 OU Soonerfan
thanks for the feedback
Watch out for your cornhole !
![]() Join Date: Jun 2003
Are you talking about the rear axle u-bolts or the front control arm u-bolts?
Either one breaking would leeave your truck grounded.
#1 OU Soonerfan
front control arm u bolts
GM went to larger front u-bolts because of this happening.
Get the bigger GM ones and it's a straight forward job. Just make sure and support the arm with a jack so the spring doesnt't fly out and make sure the lower shaft sets onto the dimple properly in the u-bolt saddle.
