Old 12-05-2004, 02:06 AM   #1
ocbaud
Garage Queen Material
rearend is back in!!!
to bad its to late to drive it tonight. i just now got done. those damn u bolts took forever to get the nuts on them. I'm tired too. tommorow it gets a wash after the rain and then its cruising time
ocbaud is offline   Reply With Quote
Old 12-05-2004, 02:37 AM   #2
r0lf-
Hotwheels?
r0lf-'s Avatar
Wow. now you can have a 0-60 in under 10 seconds
your 40-80 is prolly like 4 seconds, but whos counting
Congrats, keep us informed.
1978 Money Pit - CUSTOM DELUXE!!!!
r0lf- is offline   Reply With Quote
Old 12-05-2004, 02:47 AM   #3
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
I wouldnt lean on it to hard
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 12-05-2004, 09:13 PM   #4
ocbaud
its crazy. i'm gonna have to get used to spinning 3500 rpm's at 75mph.
and the speedo reads correctly too now
Old 12-05-2004, 09:32 PM   #5
Grande Rojo
paper or plastic?
Grande Rojo's Avatar
time for a 700r4
Grande Rojo is offline   Reply With Quote
Old 12-05-2004, 09:37 PM   #6
ocbaud
Originally Posted by Grande Rojo
time for a 700r4
thats what i'm saying.
it still pulls really nice above 70mph though
Old 12-05-2004, 09:40 PM   #7
SanitysBane
or a 4l60E or 4l80E, just what do you have money for...
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 12-05-2004, 10:48 PM   #8
1FaastC10
1FaastC10's Avatar
700R4 is a hydraulic controlled 4L60E, Eric's truck isnt wild enough to warrant the expense of a 4L80E.
1FaastC10 is offline   Reply With Quote
Old 12-05-2004, 11:31 PM   #9
SanitysBane
yes i know, and if you want to get technical, like i always do, after 87 the 700R4 are 4L60, and it wasn't untill later that they became the 4L60E, but some people like not having to worry about transmission at all so they go with overkill, like having a turbo 400 behind a 305.
'88 K5 Blazer
Old 12-05-2004, 11:38 PM   #10
Destructo
I wouldn't worry about a regular 700r4 behind his 355, its not putting out enough power to kill one, but a 700r4 would be way nicer than that th350, I couldn't stand to turn 3500rpm while cruising, but I bet it moves. 3500 rpm is what my VW with 3.94 gears and a 5 speed tranny turns at 75mph.
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
Old 12-06-2004, 01:12 AM   #11
low 84
low 84's Avatar
he definatly has enough power to kill a stock 700
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 12-06-2004, 01:19 AM   #12
SanitysBane
a stock 305 has enough power to kill a stock pre 87 700R4
'88 K5 Blazer
Old 12-06-2004, 01:43 AM   #13
ocbaud
i finally found a dry road tonight. everyother road was wet and would spin the tires anytime i floored it below 45mph it would spin and go sideways.
so anyways, i found this road that was dry. i stoped, held the brake and revved to about 2000rpms then launched it in 1st gear. without even flooring it, maybe 3/4 throttle, it got sideways and i had to shift into 2nd before i knew it by the time i was in 3rd gear i was only going about 40mph
i think i'm gonna have the same problem ryan has, finding traction
Old 12-06-2004, 02:09 AM   #14
low 84
low 84's Avatar
told ya
'05 1500 Crew Cab
RIP
Old 12-06-2004, 02:27 AM   #15
ocbaud
Originally Posted by low 84
told ya
well at least the gears woke my truck up
i'm wondering if drag radials will even help, would it just wheel hop a bunch with them?
Old 12-06-2004, 03:26 AM   #16
TIMSPEED
TIMSPEED's Avatar
You DID let the new gears work harden, right?!?!
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 12-06-2004, 03:29 AM   #17
ocbaud
i did enough
Old 12-06-2004, 11:05 AM   #18
MylilBowTie
Right turn Clyde
We will see how long it holds up. Powerbraking, new gears and posi doesn't sound to good together. Not that I want anything to happen with it. I dont think it had enough time to setup properly really. Did you let the rear end cool down when driving it short distances? I doubt this will apply to your truck. If you plan on towing anything with it you will need to be easy on it and let it cool down 3-4 times in short distances. Work hardening creates a lot of heat that's why you need to let them cool down. If they get to hot and the gear oil gets to hot them bad things can happen.
Old 12-06-2004, 01:12 PM   #19
ocbaud
i put about 100miles on it today. let it cool for the first 15 and then the next 30 miles. i didnt really get on it until i had the 100 or so miles on it
Old 12-06-2004, 01:20 PM   #20
bigblock73
yeller
bigblock73's Avatar
Might need new axles soon too.
At least you don't have 4.10's! I was getting 3000+ RPm at 60 MPH.
bigblock73 is offline   Reply With Quote
Old 12-06-2004, 02:11 PM   #21
BaggedC10
Under construction!
BaggedC10's Avatar
Install a parallel 4-link w/ F9000's behind-the-axle, Eric. Maybe that will help you gain *some* traction.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
