12-05-2004, 11:23 AM | #1 |
Comments on using a late model manual tranny?
Hey guys, after extensive searching, I have finally sourced a late model 5 speed for my truck, the overdrive transmission out of a 92 full size truck.
Has anyone used this tranny, will it bolt to an old style 350 motor (pre 85 style)? Cany anyone answer if I will have to change to a high hump for the tranny, instead of the low hump I have now? And last, how about the yolk for the driveshaft? Thanks for all the help.
ongoing 1970 c 10 lwb 1994 z-28 few mods.-owned since new 1978 vette silver/grey 25th anniv. paint |
12-05-2004, 12:53 PM | #2 |
You may have to change the bell housing, but that's not a big deal. The high hump was more for the 4X4s and the granny 4 speeds. I didn't have to change for my T5 (not the same as yours I know). You'll have to build a custom driveshaft anyway, so the yoke will take care of itself. I just bought the driveshaft and tranny together from the same donor truck. Get a good measurement, take both driveshafts to a good driveline company and have them cut, weld AND balance your new shaft.
Silence is golden, duct tape is silver. - Scott Last edited by gr8scott51; 12-05-2004 at 12:54 PM. Reason: typo |
12-05-2004, 12:56 PM | #3 |
Watch out for your cornhole !
No need to swap any bellhousing. The 92 model V8 and V6 engines and transmissions used the same pattern as the earlier GM engines did.
12-05-2004, 02:08 PM | #4 | |
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd |
12-05-2004, 03:18 PM | #5 |
I'm pretty sure that bellhousing info is correct. To retain the mech clutch, he'll need a bellhousing that mates the NV4500 and retains the mech clutch driver's side fork. Also confident AA offers such a bell housing. Of course, he can convert to a hydraulic clutch and then prolly use the '92's bellhousing.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
12-05-2004, 03:55 PM | #6 |
It's a catastrophic success.
My 90'and 92' 4.3V6 both have intergrated bellhousings and hydro clutch.
and Ive had to replace both of them. Flywheel to clutch mating and bell bolt pattern would be areas of concern. mounting a hydro mastercylinder would not be that hard. But Im not familiar with all manual trannys gmc makes, just these. |
12-05-2004, 05:16 PM | #7 |
I was speaking generally in response to Gr8scot51 about the bellhousing swap not being needed as all engine sizes in the 92 model truck (4.3, 305, 350, and 454) use the same engine to trans mounting pattern, which is also the same as Chevybill's earlier V8 uses.
12-05-2004, 06:02 PM | #8 |
thanks for all the replies, guys.
I to have a 92 chevy truck with this manual tranny and the bell housing is integrated. I definitely want to change to the old style manual clutch setup with out hydraulic assist. So any info on a bellhousing, clutch, pressure plate etc. is greatly appreciated. I have not got the tranny yet, but I know it is out of a half ton truck, not the s 10 version.
12-05-2004, 09:53 PM | #9 |
Speedometer
I am using a 5 speed out of a full size pickup as well, any suggestions to go from the electrical speedometer hookup to the mechanical one. Thanks.
12-05-2004, 10:52 PM | #10 | |
12-05-2004, 11:36 PM | #11 |
As soon as i know the exact transmission, i will post about that.
What is the difference in the 2 that you listed (poet) is one for a 2wd and the other for a 4wd? I am hoping it is the overdrive tranny with a normal 1st or low gear and for a 2wd truck- which one would that be? thanks for all your help, i just had to share that i finally found a tranny source for my truck, you all know how it is when you have a break through on a project.
12-06-2004, 01:37 AM | #12 |
NV4500 is for the 3/4 ton and 1 ton trucks and has a seperate bellhousing. Although it has a different bolt pattern than the "normal" chevy 4 speeds. AA does make a "manual" clutch linkage bellhousing for the NV4500 if you've got an extra $400-$450 laying around.
NV3500/3550/Getrag/MG5, (whatever you want to name it), is for the 1/2 ton and S-10 pickups. It has the integrated bellhousing. I haven't heard of a way to convert to the manual clutch linkage on these trans yet. and they only come with the electric speedo hookup, (2wd, 4x4 speedo hooks to the transfer case). Also the full size 1/2 ton truck version uses a TH400 style yoke and has a 30% overdrive 5th gear. The S-10 version uses a TH350 style yoke and has a 20% overdrive 5th gear.
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
12-06-2004, 11:06 AM | #13 |
Did New Venture make a model 3550 also?
If so, that is not the same as the Tremec 3550. The Tremec 3550 aftermarket 5-speed does not have an integrated bellhousing. The Tremec bolts up to the truck bellhousing, it just needs a spacer ring to make up the difference between the 4.684 in throughout retainer diameter and the 68-72 truck bellhousing diameter of 5.125. |
12-06-2004, 12:42 PM | #14 | |
Silence is golden, duct tape is silver. - Scott |
