Old 12-05-2004, 03:54 PM   #1
Deuce
Deuce's Avatar
TPI Conversion Wiring Question.
Can anybody tell me what I need to keep out of a factory 87 IROC harness to make the engine in my 68 work??
I'm in the process of pulling the motor/trans out of the car and there are a ton"o"wires!! What can I eliminate?? I want to keep it as simple as possible.
Thanks in advance!!
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 12-05-2004, 06:56 PM   #2
jiggs
poker face
Try checking out this website. www.chevythunder.com
If you could kick the person in the *ss responsible for most of your trouble, you wouldn't sit for a month.
jiggs is offline   Reply With Quote
Old 12-05-2004, 11:33 PM   #3
classicchev
classicchev's Avatar
Ive done the TBI the hard way, stripping out the old wiring harness, ITS A REAL PAIN IN THE A$$. I wouldn highly suggest a painless wiring kit, it will save you alot of grief. If you need any of the wiring schematics(sp?) I have the books that you will need. Email me if you are interested in the books, or hearing of my experience with the TBI swap. Darren
classicchev is offline   Reply With Quote
Old 12-06-2004, 08:15 AM   #4
tpi72blazer
Tpi72Blazer
tpi72blazer's Avatar
My TPI unit came from an 88IROC and had the factory harness on it as well. I decided to go with an aftermarket wiring harness. The amount of headaches and frustration it saved in the long run made it well worth the money. An aftermarket harness also makes the conversion look a lot better - the only wires you have are just the ones you actually need.
Indian - the other money pit
tpi72blazer is offline   Reply With Quote
Old 12-06-2004, 11:16 AM   #5
Russell
Professional Grade
Russell's Avatar
I rebuilt my harness, it wasn't too terribly tough, just need to be patient, and check everything three times, then solder once. There are great wiring diagrams on Chevy Thunder that can show you what all you need (most of it)
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 12-06-2004, 03:54 PM   #6
Deuce
Deuce's Avatar
What did you keep and what did you discard?? Pm me your number and I'll call you.
Old 12-06-2004, 03:57 PM   #7
Deuce
Deuce's Avatar
Darren. I'll call you and we'll have to hook up.Going to be REALLY busy with work this week.
Do you want to sell your books/manuals??
Did I PM you my home number??
Old 12-06-2004, 04:00 PM   #8
Deuce
Deuce's Avatar
I think 1/2 the fun is making the factory harness work. Otherwise it's kinda like buying a truck already painted(not that theres anything wrong with that, just not as much fun)
Old 12-06-2004, 08:29 PM   #9
Russell
Professional Grade
Russell's Avatar
I'd agree with you doing the harness yourself
The only stuff I found I was pulling out was AIR system stuff, and the 700r4 lockup stuff (if I remember right...) I am using the EGR on my setup. Just need to find a solenoid for it now...
If you need any help with the harness, feel free to PM me here, or send an email to Russell@ZieglerDigital.ca.
I should have my unit fired up pretty quick, just gotta break my cam in, and drill my headers for the 02 sensor bung...
Old 12-06-2004, 11:52 PM   #10
classicchev
If you want to buy the books that should be no problem, i really doubt I will be using them because I am buying a Ramjet tomorrow, nice easy hookups. Pm me if you would like to see the books. Darren
