column shifter arm removal
how do you remove the shifter arm. I just installed a megashifter and would like to remove the stock column arm. Thanks
![]() Join Date: Aug 2001
![]() THERE IS A PIN AT THE BASE OF THE SHIFTER ARE HOLDING THE ARM TO THE COLUMN. DRIVE THAT PIN OUT & THE SHIFTER ARM WILL PULL RIGHT OUT OF THE COLUMN. ![]() ![]()
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
