Shaved
front bag question
Is it the same proceedure baggin the front on a 69 GMC as it would be a 69 Chevy. I mean, do the suicidedoors plates bolt right up the same way? Also, what do you all reccomend on the rear? thanks, Jody
1969 ![]() |
its just $$$$$
yes, should be exactly the same.
Shaved
Ok, thanks for the quick reply, now all I have to do is save up lol
1969 ![]() |
17's too small
those plates are cheap, but two sets so you are ready to go on your next project. LOL
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows |
Head Peon
![]() Join Date: Dec 1999
Check out this thread for a simple answer for the rear:
http://67-72chevytrucks.com/vboard/s....php3?t=129463
'72 Suburban, factory tilt, tach, front & rear AC, front & rear disc brakes, 383/700-R4 |
Shaved
thanks
1969 ![]() |
GM ONLY BABY!!!
What about us leaf spring guys? How much drop will we get from the "air over leaf" kit?
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
Head Peon
I guess the answer would be as much as you dearch the springs...air over leaf is meant more to be used as an "overload" spring than to drop your ride. Don't get me wrong, guys run it to get low, but have to dearch your springs and pretty much only run the main spring. You take the chance of the spring breaking, which gets ugly quick. I apologize for the poor explanation (brain isn't working well right now...LOL) hopefully somebody else can translate my blah blah. You could always switch over to trailing arm...ECE crossmember plus a set of trailing arms and axle mounts and you'd be there...then running a regular bag setup would be a cinch...pretty much bolt on except for the axle mounts...
'72 Suburban, factory tilt, tach, front & rear AC, front & rear disc brakes, 383/700-R4 Last edited by Shev; 12-09-2004 at 11:10 PM. |
GM ONLY BABY!!!
Here's some info, but I am curious as to how much drop is obtained from this.
http://www.airride.com/productinfo/airoverleaf.asp
Head Peon
I guess my next answer would be to either email or call AirRide and see what they have to say...most guys that try going the air over leaf way end up going with some sort of link setup in the end. Air over leaf is great for additional payload...
#11 | |
Happy to be here
![]() Join Date: Mar 2000
Happy to be here
2.........
