Anyway of Converting a Auto Tilt to a Manual Tilt??
Can the auto shifter mounting collar be replaced with a manual tranny collar?? Thus ending up with a 4spd tilt column??
I know what your thinking.......I have ESPN. ![]() Sometimes it's easier to do things the hard way. ![]() Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! ![]() ![]() |
My other Love
take the shifter off, the indicator off, die grind the the bung for the shifter, voila, standard tilt column
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
Member #1049
Another way is to find any 1968 Pontiac Bonneville.. Firebird.... Olds.. Delmont 88.. Cutlass.... or Chev Impala..Chevelle... Camaro.. that came with the console mounted shifter.. (or a 4spd car).. and just swap the shifter collar and the turn signal housings.. ( a bolt for bolt swap)... then cut off your lower shift lever remove the neutral safety switch and jumper across... Viola.. You have a truck 4 spd tilt...
Yes the 1968 Vintage GM cars are not real plentiful anymore.. but they made bunches of them with that option.. They are way easier to find than the factory truck tilt... In fact of the hundreds of trucks I have owned in the last 25 years.. I have only had two with the factory floor shift tilt.. |
Post Whore
![]() Join Date: Feb 2000
I did what Hooter mentioned above. Pics at http://drunken.b0xen.us/yukon/albums/vantilt/
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
I guess that works too. I have a auto tilt with a loose pivot pin and I want to run a TALL Lokar shifter.
I was wondering if you could change the whole collar with something you can presently buy??
