Where to mount mufflers?
Does anyone have any feedback on mounting the mufflers under the cab? I plan on running the exhaust out the bedside in front of the tires on both sides. I am running 2 1/2" pipe through the frame and want to mount 40 series flowmasters between the tranny and frame. What is your opinion?
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
Wow, that's "exactly" what I did, 40 series Flowmasters, 2 1/2 pipes the same exact way. My Flowmasters are about 12 inches behind the header flanges.
-Praise the Lowered-
Just got done re-routing my exhaust. I love the sound of flowmasters, however, when mounted just beneath the cab, the sound resonates inside the cab. Gets old really fast. I ended up mounting mine underneath the bed, and dumping infront of the rear end. Sound perfect. Rumbles really well, but doesn't echo inside the cab.....
Go to this thread.... http://67-72chevytrucks.com/vboard/s...=exhaust+comin
Race-N-Jason ('71 Chevy C-10 LWB 454/TH350) ('07 Dodge Ram 2500, 5.9 Cummins/6-speed Manual) |
#4 | |
Still drivin' a Rat Rod
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
race-n-jason how does that big block run.
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd |
its all about the +6 inches
under the cab does get old pretty quick. Esp if you do any road trips.
Ear plugs should not be maditory for doing over 60 MPH. Plus,a little known minor fact, the exhaust is less restrictive when you place the mufflers further back. Also, turn downs are not a good idea, the exhaust is corrosive and is not good for the sheetmetal...not to mention, poverty pipes simply suck. |
67-72 Addict!
Come on Andy, ther'e's nothing like the sound of turndowns bouncing off the pavement
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
loud is one thing...annoying as a complete other thing.
I honestly prefered open headers to under cab mufflers. At least with open headers, you don't even try to talk to your passengers. |
I'mnot talking about pipes under the bed side I mean through the bed side in front of the wheel. Read the post. I know it will be noisy but the truck is not a daily driver. I plan on putting ALOT of sound deadening material in the cab anyways. It has a 25.5" talltire and 3.73 rear so highway driving is noisey already add a PJ geardrive and 40 years of use and I'll take what I can get. Thanks for the replies. Randy how do you like the sound of your setup?
I was kinda addressing your question, and the turn down idea listed in this thread at the same time.
I read it twice before responding. ![]() |
