12-06-2004, 02:54 AM | #1 |
Pvc Setups on a 68 with 327
Can anyone tell me what kind of pvc setup was used on a 68 1/2 ton with a 327?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
12-06-2004, 03:01 AM | #2 |
Typo. PCV is correct
12-06-2004, 03:30 AM | #3 |
Still drivin' a Rat Rod
There is none on the 67 327 1 ton we have,just the canister in the lifter valley.I'm not sure if that is the stock setup,but there is no holes in the valve covers where it should be.
All the blowby comes out of the oil filler tube,and straight into the cab <choke cough>Stinks too
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
12-06-2004, 03:43 AM | #4 |
Any motor that is pre 69 will have no provisions in the valve covers for a breather. They used the oil filler tube in the intake and a canister with road draft tube out the back. Some of them had an adapter in the place of the road draft tube that a vacuum line hooked up to like a pcv. All of the old blocks had a place in the back next to the dist for the road draft tube and the corresponding canister in the lifter valley. they also used an intake with oil filler hole. I ran into this problem with my 327 cause I used a newer block with old valve covers and intake. I have a vent through the filler tube but no way to pull air through the block. we drilled and tapped the intake for a chrysler pcv valve but it pulls too much oil vapor from the lifter valley and burns it. the thing looks like it has bad rings or valve guides cause it leaves a blue cloud. We are in the process of fabricating a canister type setup to slow down the air and get the oil droplets out before sending it back into the engine.
Hope that gives you some info. Nathan
69 C-10, 340HP 327 55 chevy 4 door 150 47 Willys CJ-2A 05 Harley Night Train 06 1200 Sportster (Wife's bike) 70 Honda CL350 OIF2 & OIF7 Veteran Nathan & Tiffany |
12-06-2004, 03:48 AM | #5 |
My 68 327, completely stock, has the PCV setup on it. One hose going from drivers side valve cover going to base of carb, passenger side valve cover has PCV valve in it... or something like that. I can't remember too well at this hour. |
12-06-2004, 04:11 AM | #6 |
ok maybe it is 67. It's the ones that use solid valve covers if you have a pcv in the covers then you are set.
nathan
12-06-2004, 04:14 AM | #7 |
It's one of those years in there. All I know is that it signaled the beginning of the emissions controlled, power-choking era
12-06-2004, 09:42 AM | #8 |
My 68 327 has a stock PCV valve too. I don't remember how everything's piped up but I can snap some more pictures for you if you want skokie.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles. TREASURER, Drum Brake Club. |
12-06-2004, 11:09 AM | #9 |
its just $$$$$
my 68 with a 307 has a pcv valve in the valve cover also.
12-06-2004, 07:13 PM | #10 |
Toms68cst pics would be good.
