Old 12-06-2004, 04:54 PM   #1
67chevemall
67chevemall's Avatar
Metering plate/block???
Whats the difference between a secondary metering plate
And a secondary metering block!!??
Any pics?
Just trying to get my carb going, but ordering renew kits for the 4150/4160
Holleys is driving me nuts!
Fits Holley model 4160 carb, 3310, square flange Holley with primary metering block and secondary metering plate.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 12-06-2004, 05:02 PM   #2
cableguy0
the metering plate has to be drilled to go up in jet sizes and the metering block you can change jets out with normal jets plus the metering plate in the back wont have a power valve and the metering block will. personally i like the metering block better much easier to change jets
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 12-06-2004, 08:58 PM   #3
69ChevyLB
Active Member
69ChevyLB's Avatar
If it's a 3310-1 which is a 780 CFM you need the 37-1084 renew kit, otherwise the 3310-2 or -3 or -4 which are 750CFM take the 37-754 kit.
69 C10 LWB Project
47 Cushman Scooter Project
It is better to have loved and lost than to live with a psycho all your life.
69ChevyLB is offline   Reply With Quote
Old 12-07-2004, 12:20 AM   #4
Peregrine
Peregrine's Avatar
Plates were used to car manufactures could put high performance carbs on cars cheaper. If I remember right, they usually had blocks on the primaries and plates on the secondaries. I got that info out of a 30 year old book though. Not like Holley changes much though....
Brian
72 C10 longbed 350/th400
Let the world change you and you will change the world.
Peregrine is offline   Reply With Quote
Old 12-07-2004, 11:37 AM   #5
67chevemall
Yes it seems the cheaper 4160 has a plate on the sec. and the
4150 and 4500 have metering blocks on the primary and sec.
Thanks I'm going to use the metering blocks so I can change the jets!
Now I need the renew kit for a 4150
Jegs and Summit want $80 USD!
