Old 12-07-2004, 12:02 AM   #1
micscottj
Help!! My alternator is killing my battery.
i have installed a 120 amp high output alternator on my 74 chevy truck. now my battery is being drained by the alternator when the truck is not running. otherwise it charges fine. I ran the red wires on the alt plug back to the battery wire like someone told me. i suspect that is the problem. if i unplug the alt it does not kill the battery.
micscottj is offline   Reply With Quote
Old 12-07-2004, 12:50 AM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Here is wiring diagram for a internal regulated alternator.
http://www.rowand.net/Shop/images/al...o1985Buick.jpg
gchemist is offline   Reply With Quote
Old 12-07-2004, 12:56 AM   #3
TIMSPEED
TIMSPEED's Avatar
I GURANTEE you have your wires crossed on the voltage regulator. I had the SAME problem a few weeks back. Swap the wires on the voltage regulator and you'll be good to go. I think it's 12v+ constant at A and 12v+ switched at B.
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 12-07-2004, 08:44 AM   #4
Blue Beard
Blue Beard's Avatar
This might solve my problem too....been running the wrong direction I think...
Thanks guys....check it out tomorrow
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 12-07-2004, 04:11 PM   #5
1980chevy4x4
Got Mud?
Yea myne to, but what is the voltage reugulator and were is it located?
Dan
Got mud?
1980chevy4x4 is offline   Reply With Quote
Old 12-07-2004, 09:56 PM   #6
1980chevy4x4
Got Mud?
T T T
Dan
Got mud?
Old 12-07-2004, 10:41 PM   #7
gchemist
gchemist's Avatar
The voltage regulator is inside the alternator. It is directly under the #1 and #2 location. Look through the slots and you'll see it. The part regulates the voltage out of the alternator. If it did not the volts would go through the roof at high RPMs. Drop like a rock at idle.
Old 12-08-2004, 09:22 PM   #8
1980chevy4x4
Got Mud?
What is the #1 and #2 location?
Dan
Got mud?
Old 12-08-2004, 09:29 PM   #9
TIMSPEED
TIMSPEED's Avatar
Says on the Alternator. #1 is drivers side pin, #2 is passenger side pin.
See Them Here
