12-07-2004, 08:16 AM | #1 |
Vortec in the works
Rear Brake Interchange
Can I use the baking plate and brakes from my 6 lug rear and put them on a 5 lug rear and get new drums? Also I heard you can use later model rear brakes??
68? It's all figured out untill you get it apart. Is it Sunday yet??? 68 Project 68 SWB frame off/98 Vortec with stock FI/power everything. 95 ECLB 2500 with 346,000 on the clock(the original HD) 99 Lesabre-wifes ride 08 Crew Cab LTZ-All Mine 89 SWB 5/7 drop-Son's first ride. |
12-07-2004, 02:21 PM | #2 |
Vortec in the works
anyone?
12-07-2004, 03:04 PM | #3 |
You should be able to, I would just have the drums drilled for new pattern.
64 Panel Rebuild Pics Clutch Replacement and Borg Warner T10 Trans Rebuild 64 Panel 1/2 Ton 350cubes/400hp BorgWarner t-10 3:73 Auburn Posi |
