Old 12-07-2004, 01:26 PM   #1
tkeduk8r
tkeduk8r's Avatar
wiring harness swap???
More engine swap stuff.... as you guys have prolly read i was going to do a "quick" engine trans swap in my 74 c10... was a 250/3 tree now i have a 305/2004r combo... now my question is this... I have a 79 instrument cluster with volt and elec oil pressure gauge in my cab (easy swap if you have idiot lights originally) BUT i have a complete underhood engine wiing harness out of a 74 Cheyenne Super with a V8/TH350... can i use that harness and be ok with the voltmeter instead of ammeter??? I do have numerous gauge clusters with all combos ammeters, and wet o/p gauges, so i could easily make he swap, but i would hate to smoke some wires if i do the swap... the 250 harness is not to freindly lengthwise with the 305... any sugestions??? I will get some pics up as soon as i get the pc at home to be nice with photoshop... thanks people...
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 12-07-2004, 01:39 PM   #2
beaterC10
You won't be able to use the voltmeter with the harness designed for an ammeter.
beaterC10 is offline   Reply With Quote
Old 12-07-2004, 03:51 PM   #3
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Ditto on what BeaterC10 said.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 12-07-2004, 04:55 PM   #4
tkeduk8r
tkeduk8r's Avatar
hmmmmmm.. so im wondering if the factory interior idiot light harness is compatible then with the engine compartment ammeter harness or would i have to change out both??? i can make the original six cyl harnesss work, just have to splice length int o some wires and section others, but if i can gethe fact v8 harness to work it would be a little cleaner install ...
--Mike
