Old 12-07-2004, 01:29 PM   #1
67ChevyRedneck
67ChevyRedneck's Avatar
Who has done a blazer tank conversion???
I know there are about 50 threads on this, but I haven't seen one that really describes how to do it. I'd hate to buy a new blazer tank and it be a pain in the you know what to put it in. I have a 67 swb, short wheel base here in the South ,STEPSIDE truck. If the tank fits between the frame rails where the spare tire should go, do any crossmembers need to be removed, moved or slightly modified? Where does the filler neck come out of the tank? A stepside bed drops below the wood floor several inches on the sides, will this need to be cut??? What about mounting it? If I purchase the stock blazer straps will these bolt to current members, or do i need to make something? I plan on buyin a cool cap, they were recently featured in classic trucks magazine, and put it in the driver side fender on the flat panel on the side in the rear. If I use this set up, cool caps don't have a filler neck vent, how can I vent my tank without dirt getting into the tank. CT didn't address that in the article, they just mentioned you need to somehow vent it...some "how to" article, huh? I want to use a blazer tank because the sending unit will work with my stock gage...right??, and I figure the swap to cost about $375, that would be tank, sending unit, new hoses and lines, and cool cap.
Anyway, any stepside guys out there who have done this swap, your input would be greatly appreciative. Also, pictures would be even better, especially ones with the bed off....
67ChevyRedneck is offline   Reply With Quote
Old 12-07-2004, 03:15 PM   #2
jorgensensc
jorgensensc's Avatar
Here is an install that I did and wrote up:
Link to Blazer Tank Install
And here is the fuel fill:
Side marker fuel fill
Hope it helps some.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 12-07-2004, 04:15 PM   #3
67ChevyRedneck
Thanks a lot man!!! That was exactly what I was lookin for. It's tight, but it works! I don't have side markers and I don't want them, so I can't do what you did, which looks absolutely great and was a sweet idea. I think it was the 55 chevy car that had it behind the rear taillight. I might just try using an S-10 door in the bedside, or something similar that is flat.
