12-07-2004, 06:12 PM | #1 |
54-55 A D truck rear wheel
I have the truck apart and I would like to center the rear wheel in the fender opening.Question is without putting the bed back on how much to the rear do I move the axle to center the wheel.This is on my 55 GMC 1st series with stock springs and hangers.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
12-07-2004, 07:53 PM | #2 |
Fabricate till you "puke"
I cant answer the ?, but just a thought.....how about moving the location of the fender on the box? crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
12-07-2004, 10:39 PM | #3 |
Box and fenders are just painted, and I have to shorten the driveshaft 2 1/4" and the wheel need to be centered in the opening so I guess I will split the difference +/-, unless someone can give me the exact measurments
