Old 12-07-2004, 07:02 PM   #1
corn
Front drop springs?
I just bought a set of new 3" drop springs from a board member & stood one of the springs beside a stock front. WOW the new ones are quite a bit shorter just sitting there. Is this going to cause problems whenever I jack the front end up in the air? They look like they will be a real pain to keep in the pockets. I always thought they were the same (unsprung)height until there was aload on them...corn
corn is offline   Reply With Quote
Old 12-07-2004, 08:45 PM   #2
swervin ervin
You get what you pay for
swervin ervin's Avatar
Nope, they are probably right. I have 1.5" springs along with my 2.5" spindles and when I jack up the truck, they are not real tight. When I had 2" coils in it, they would move when it was jacked up. I'm sure someone with 3's will chime in but I imagine they would probably move around pretty good when raised.
BTW, they are supposed to be shorter, unsprung.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 12-07-2004, 09:09 PM   #3
corn
Thanks Mike. Im hoping to stick them in this weekend. 6-8 here we come...corn
Old 12-08-2004, 12:06 PM   #4
44th Miss Inf
You can put a longer rubber bumper on the bottom of your upper control arm, or a spacer on the front crossmember where the bumper contacts. That will limit your downward travel to keep the springs in the pocket while jacking.
Virgil
44th Miss Inf is offline   Reply With Quote
Old 12-08-2004, 02:09 PM   #5
leastbay
i have 3 inch springs and they stay in there pretty good actually when i put the right side on and bolted the control arm in i didnt realize that it wasnt in on the top and i just drove it down my driveway and it popped in place
leastbay is offline   Reply With Quote
Old 12-08-2004, 02:48 PM   #6
8t5Silverado
Mudslides 'r my specialty
8t5Silverado's Avatar
Just put your jack under the ball joint when you jack it up...
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.)
http://www.cardomain.com/memberpage/500339
8t5Silverado is offline   Reply With Quote
