12-07-2004, 11:34 PM | #1 |
pics for spraypaint
hey i thought i would post pics of the brake drum.It looks like a 3/4 ton drum with dauley adaptors on it.These are factory 67 1 ton drums.I need to give thanks to my little helper in pic three!!Thanks Brett.in pic two the inside of the drum it looks like the hub is removable by un doing the studs
12-08-2004, 12:15 AM | #2 |
its all about the +6 inches
That's not really an adapter, it's just the hub for a dually. I have one on the one ton.
12-08-2004, 11:03 AM | #3 |
ttt
12-08-2004, 11:38 AM | #4 |
Would you happen to have a dial caliper to get the exact measurement of the shoulder where the wheel centers on the hub? The wheels I bought from Southwest wheel have a center bore like 4.56.
Any idea on shipping to Kansas City, MO? |
12-08-2004, 06:18 PM | #5 |
the hub center is the same as the 3/4 tons[tried a wheel on it]do you want just the hub?or the drum too?
12-08-2004, 06:29 PM | #6 |
Well, i guess i'm needing both, what you show in your pictures. And that is going on the assumption that I can simply pull the existing C20 drums and hubs and slide these huge things on. It almost sounds too simple, too good to be true. I generally don't have that kind of luck... Price is ok, it's just the shipping that I'm not looking forward to, especially if there's a snag. And at Christmas time, the wife is watching my fun money...
12-08-2004, 10:28 PM | #7 |
yes...remove and install.
12-09-2004, 11:24 AM | #8 |
You said in one of your pm's that the drum was 12". Not exactly sure where you were measuring. My drum inner diameter (brake pad surface) is 11 1/8" across and brake pads are 2 3/4" wide. Could you verify these measurements on yours?
12-13-2004, 10:29 AM | #9 |
pm ed you spraypaint
