Old 12-08-2004, 04:43 PM   #1
hotrodhomi
hotrodhomi's Avatar
Bolt-On 4 Links And Cantilevers
What is the difference in a Bolt-On 4 Links And Cantilever? What is better for air? I'm trying to put together a shopping list and Im not sure what is needed for the rear. I have a '81 swb. Will I have to relocate my gas tanks? I have the stock dual tank setup.
Linky
hotrodhomi is offline   Reply With Quote
Old 12-08-2004, 05:53 PM   #2
MP4/8
The four link is just that, the four link. The cantilever is an add on for mounting the bags on, and both giving more lift, and softening the harshness that double convoluted bags mounted on the axle usually have. With the KP kits you linked to, the four link can be used with out the cantilever. But you will need to get bag mounts for it. And the canti is made to attach to the bolt in four link, and has bag mounts and shock mounts ( and shocks ) with it. or they do offer some brackets to use it with a weld in four link kit.
Hope that answers your questions
MP4/8 is offline   Reply With Quote
Old 12-08-2004, 06:00 PM   #3
hotrodhomi
hotrodhomi's Avatar
what causes the cantilever to be less harsh? is it the location of the bags?
Old 12-09-2004, 02:02 AM   #4
NotLowerThanMe
NotLowerThanMe's Avatar
A cantilever or a leveraged 4-link change the stroke that the air bag gets by putting it on more of a 2 to 1 ratio. Essentially by moving the placement from over the axle to in front of the axle you can get more lift at a lower psi. It gives the truck a softer ride.
Say you need 80psi to get the truck to ride height in a over the axle setup. At 80psi it might ride really stiff. Move the bag forward of the axle on the link bar and now you may only need 50psi to get to your ride height.
One downfall of a leveraged or cantilevered setup is that moving the bag to far forward will create to much lift and not enough pressure and the truck will squat and feel loose while your driving it because its just to soft.
On trucks I build I try and stay around 12 inches of lift max. Anymore than that seems pointless.
I hope that helps explain it.
Nic
www.crazytalkcustoms.com
NotLowerThanMe is offline   Reply With Quote
Old 12-09-2004, 11:40 AM   #5
hotrodhomi
hotrodhomi's Avatar
that info was great. Do you have to use a 4 link with a cantilever?
Old 12-09-2004, 12:08 PM   #6
MP4/8
No. In fact most don't.
Old 12-10-2004, 02:35 AM   #7
BK
BK Built
BK's Avatar
i believe placing bags up on the trailing arms on the 60-72 frames would be a type of canteliver, gives us lots of lift, and a great ride, its what im doing.
BK is offline   Reply With Quote
