Old 12-08-2004, 10:11 PM   #1
RapidRide2
Rear Main Seal install
Shoooo,,, it has been a month since i have been able to log onto this board???? Why i have no idea,, but was able to log in tonight. My question is as follows,,, Can a rear main seal be replaced on an 83' gmc full size 1/2 ton automatic 305 without jacking up the motor???? Will the pan clear the oil pump pickup and crossmember simultaneously?????? Also,,, has anyone ever had any success with the new one piece oil pan gaskets???? P.S. is the rear main the only thing that would leak without the engine running??? quite a bit of oil is dripping down onto my crossover pipe then the ground. The truck has hardly been driven.
RapidRide2 is offline   Reply With Quote
Old 12-08-2004, 11:01 PM   #2
SanitysBane
yes the oil pan will clear with out jacking up the engine, it did on my C10
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 12-08-2004, 11:12 PM   #3
Devil'S Ride
The oil pan should clear, if I remeber correctly, and yes, get the fel pro one piece gasket....it is WELL worth the money...I have used them several times now, and I believe Fel Pro has found a winner!
The Devil
1983 ONE TON 454/400/208 11" of lift on 44's
Devil'S Ride is offline   Reply With Quote
Old 12-09-2004, 06:52 PM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
I replace my oil pump not 2 months ago. Definitely not a problem.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 12-10-2004, 01:44 PM   #5
loblazer
loblazer's Avatar
Ok guys, can you give a little more info on how to do this? Mine is leaking too. I have heard it can be done with the two piece, how do I get it done if I buy a Fel pro?
Thanks, Doug
loblazer is offline   Reply With Quote
