![]() Join Date: Jan 2002
Wtb: Column Shift Linkage
LOOKING FOR 'ALL' THE NECESSARY LINKAGE TO HOOK UP STOCK SHIFTER FROM COLUMN TO TRANS (3spd MANUAL V8 1972). I HAVE A SHIFTER COLUMN THAT HAS HAD LINKAGE REMOVED. ALSO NEED SHIFT ARM.
THANK YOU! Last edited by CARS4567; 12-09-2004 at 07:45 PM. |
I have everything you need from the trans up to the firewall hookup $35 plus the ride
shifter
I will pm you-thank you
"Trucks with Class"
![]() Join Date: Jul 2000
Which trans?
They are different: TH400 vs TH350.
If you are looking at used, be careful of worn out/sloppy parts. I use & sell a nice kit that replaces all of that old GM stuff with stainless. It looks better and gives more clearance. When you come down for those GMC caps, I will show you. |
shifter parts
thank you Frank...will do!
Shift Linkage
I WAS NOT 'CLEAR' ABOUT THE TRANSMISSION IN THIS TRUCK....IT IS A 1972 W/307 AND A 3sPD MANUAL .
THANKS AGAIN FOR ALL THE HELP! Last edited by CARS4567; 12-09-2004 at 07:45 PM. |
Shifter
Ttt
