Old 12-08-2004, 11:35 PM   #1
solidaxel
solidaxel's Avatar
Floorboard 54 55 1st series
Question, are the floorboards the same for a 4 speed as a 3 speed?
Is the inspection cover over the transmission the same from 48 to 55 or are there 2 different ones?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-09-2004, 01:14 AM   #2
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
The one for the 4 speed has a hole in it for the shifter.I can take a pic of mine tomorrow if it'll help ya.It has a factory 4 speed in it.I think it's basically flat though.
My memory is not what it used to be
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 12-09-2004, 07:32 AM   #3
Apache
Apache's Avatar
The 3/4 ton we have down here has a 4 speed cover and it is sligtly raised with the hole for the sifter. The 54 im working on (and other 47-55 trucks we have) have a flat floor board because of the 3 speed. I think all 3 speeds were flat and 4 speeds were raised a bit with a hole, I know this is the way the later 55-59's are.
The floor in my 58 was flat and when I put the 4 speed in I had to change the floorboard panel. The one in it now is raised a bit with the hole for the shifter, hole for the hand brakes (my truck has 3 brakes. regular brakes, cable/hand brake, and brake on the trans), and hole for the kick start. Id imagine the 54 and 55 first series was basically the same way.
54 Chevy Bel Air 4dr powerglide
54 Chevy SWB
58 Chevy Big Window SWB Fleetside project
58 Chevy LWB 235/4spd
76 Chevy Nova 350/TH350 4.88's *10kmiles on "new" engine
79 Chevy 4x4 SWB 350/4spd 3/4 ton
81 Mazda RX7
84 F@!d Mustang
96 F@!d Ranger 2.3L/5spd
Apache is offline   Reply With Quote
Old 12-09-2004, 10:09 AM   #4
solidaxel
solidaxel's Avatar
From the sounds of things there are 2 inspection covers Thanks I guess I will start looking for a 4 speed cover as mine is flat with the rest of the floor.
I am changing the B/W 4 speed to a Tremec 5 speed and from just looking at it out of the truck it is about 2" taller from the centerline!!
Thanks for the replys.
LS 3 4L70E
Old 12-09-2004, 10:29 AM   #5
Apache
Apache's Avatar
Here are too pic (bad pics) of the floor of the 3/4 ton. Its hard to see because of the thick rubber mat and other junk in the floor. If you need a better pic I can get one later after I move some stuff out of the floorboard and pick the mat up out of the floor. It was raining and I was already soaked or I would have done it just now lol. Also is a pic of my 58. The one for the 54 and 55 first series will be about as high as the one in my 58 except it doesnt cover such a large area. On the 54/55 I think the raised part is only around the shifter. Whenever I get a change to pick the mat out of the other truck I can tell you for sure.
54 Chevy SWB
81 Mazda RX7
84 F@!d Mustang
Old 12-09-2004, 06:56 PM   #6
solidaxel
solidaxel's Avatar
Apache,
Thanks for taking the time to send me the pics. It looks like the top two photos do not even have a inspection cover and the bottom one is much larger than my 55 1st series, I take it is from your 58 correct?
LS 3 4L70E
Old 12-09-2004, 08:24 PM   #7
Brainchild
Brainchild's Avatar
I forgot to take my Camera to the shop with me I must be getting old
I will take some pics of the 49 tomorrow.
Rusty Member #13872
71 GMC LWB
49 Chevy
85 Chevy G20
Old 12-09-2004, 11:11 PM   #8
Apache
Apache's Avatar
Yes, the bottom one is from my 58. Its about the same height raise as the 54/55..but is raised over a much larger area.
54 Chevy SWB
81 Mazda RX7
84 F@!d Mustang
Old 12-10-2004, 04:42 AM   #9
gregbr
Senoir Member
gregbr's Avatar
I think the floor is the same in both, the trans covers are different.
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4"
70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010
70 GMC Restoration Pictures
http://67-72chevytrucks.com/gallery/...00&ppuser=4424
gregbr is offline   Reply With Quote
Old 12-10-2004, 08:05 PM   #10
Brainchild
Brainchild's Avatar
I remembered to take my Camera today
Here are the pics of my floorboard.I believe this is original.
Rusty Member #13872
71 GMC LWB
49 Chevy
85 Chevy G20
Old 12-11-2004, 08:34 PM   #11
Apache
Apache's Avatar
Yes the floor should be the exact same, just the cover over the trans is different. The pic of the one in my 58 should show that the best (you can see the line where the cover meets the floor better), and the 54/55 should have a plate that can be replaced too.
54 Chevy SWB
81 Mazda RX7
84 F@!d Mustang
Old 12-11-2004, 08:46 PM   #12
solidaxel
solidaxel's Avatar
Thanks for your help, I have more problems now that it is all mocked up. Everything fits too good !!!! By that I mean when I install the engine trans combo as a unit it fits within inches of the seat apron. Long term if I need to change throw out bearing or clutch everything will have to be removed or cut the floor and seat apron to move the transmission back to clear the bellhousing 5". Don't you just love these hot rods !!!!!!!!!!!!!!!!
I tried to attach a photo but it is too large by 9kb
LS 3 4L70E
Old 12-11-2004, 11:39 PM   #13
Brainchild
Brainchild's Avatar
FAQ on posting pics.Working on these ol rides can prove to be a challenge for sure.
Rusty Member #13872
71 GMC LWB
49 Chevy
85 Chevy G20
