12-09-2004, 04:44 PM | #1 |
belly dragger
Z'ed tranny crossmember
Here's our new tranny crossmember for 2" Z'ed frames
12-09-2004, 06:53 PM | #2 |
Project92 SWB stepside
Nice looking piece but I would think it needs a little more support to keep the frame rails from flexing. Kinda like the factory unit which bolts top and bottom of the frame rails.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
12-09-2004, 09:12 PM | #3 | |
Under construction!
I agree. I would prefer the X-member be one solid piece of round tubing and I would not retain the factory ends. The ends looked too "tacked on". A one peice mandrel bent piece would be sweet. JMO.
2001 Silverado bagged on 22's. *Sold* |
12-09-2004, 10:25 PM | #4 |
belly dragger
Those aren't the factory ends they are actually laser cut for one of our other trans cross members. Unfortunately the pictures don't really do it justice
12-09-2004, 11:12 PM | #5 |
Head Peon
Any particular reason it's not a solid piece of tubing (my guess possibly it was that way just for R&D)
'72 Suburban, factory tilt, tach, front & rear AC, front & rear disc brakes, 383/700-R4 Last edited by Shev; 12-10-2004 at 08:26 AM. |
12-10-2004, 02:32 AM | #6 |
BK Built
excuse me if im wrong, but wouldnt the u-joint between the yoke and the driveshaft take up most of the angle between the tranny and rear end?
12-10-2004, 09:22 AM | #7 | |
Mike
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
12-10-2004, 12:29 PM | #8 |
BK Built
how far below the frame did the original auto x-members hang? Im wondering, as i plan to z my frame in the next week or two, and i currently have an ECE auto tranny crossmember which is totally out of the way, doesnt hang down at all. THanks.
12-10-2004, 01:55 PM | #9 |
DroppedChoppedPanel
Just incase you don't know. You tranny and the diffirential should be within 3 degrees of eachother.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
12-12-2004, 12:26 PM | #10 |
I wouldnt worry as much about the trans output shaft angle as I would with the pinion angle. Take a look at any lifted 4X4 out there, they are WAY off. Heres the x-member I did for mine but Ive now changed it a little(raised 1 1/2")...corn
12-12-2004, 03:16 PM | #11 | |
12-13-2004, 11:01 AM | #12 |
belly dragger
Yeah this isn't our first trip the the store. You will find with bagged trucks that there are alot of variables with driveline angle that have to be compensated for.
12-19-2004, 02:11 AM | #13 |
BK Built
i have the ECE auto tranny crossmember, and i was wondering if i just flipped it over would that work for a 4" z, or if i sunk it into the crossmember a little that should work right?
