Old 12-09-2004, 05:41 PM   #1
67chevemall
67chevemall's Avatar
how many use fuel regulators?
Just wondering if a fuel regulator is a good idea or not?
I know I want a gauge but maybe a reg. too!
What is the best fuel pressure for a 350 block with a holley 4150 carb?
Cheers
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 12-09-2004, 06:32 PM   #2
cableguy0
the most common regulator is made by holley if you buy it from edelbrock you will find they just ground off the holley logo. and yea i run one i have no choice electric holley blue pump
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 12-10-2004, 12:24 AM   #3
SweetandLong68
Your UncleBen
SweetandLong68's Avatar
Hey,
It is always a good idea to run a fuel pressure regulator. Closer to the carb the better. A gauge on the regulator or between the regulator and the carb is a definete good idea. One of the 0-15psi variety will serve you well.
But yes...It is always a good idea to use a regulator. That way you can know what pressure you are running. And if you use a carb like a edelbrock...you have to run a regulator or your engine will run like crap.
lata
CHRIS
68 C10 shortbed -- Street/Strip
SweetandLong68 is offline   Reply With Quote
Old 12-10-2004, 10:06 AM   #4
Blue68
Blue68's Avatar
Hmm...I've run an Edelbrock for many years without a regulator and run just fine. With both a mechanical and electric fuel pumps.
Why do you guys say you have to? So long as your pump isn't of a higher (above about 7psi) flavor, right?
http://home.comcast.net/~r.landrum/w...tos.html-.html
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Blue68 is offline   Reply With Quote
Old 12-10-2004, 12:21 PM   #5
67chevemall
I'm confused at what pressure to set the regulator?
How do you tell your at a "good" pressure?
Just by the way the truck runs, or can you tell by looking at the fuel mist?
Or ??
Is there a factory pressure that GM set for 350 blocks with 4 barrels??
Old 12-10-2004, 12:33 PM   #6
toddtheodd
The oddest Todd around
toddtheodd's Avatar
Originally Posted by ZOOMY
If you're running an Edelbrock carb, you had better use one.
Maybe that's what's the matter with my truck.
What is the psi supposed to be for an edelbrock?
Todd
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan
IIOY???
toddtheodd is offline   Reply With Quote
Old 12-10-2004, 01:17 PM   #7
Bowtiefreak
Bowtiefreak's Avatar
Eddy carbs typically don't like anymore than 4-5 psi. Holley's run well at 6-7psi. Anymore than 7 psi on a Holley and then they typically start to be more than the needle and seats can handle and then they just start to flood over.
1968 Chevy C10 Short Fleetside/Wood floor
ECE 4-6 Drop / 406 Small Block
1971 Chevelle 427 Big Block
Bowtiefreak is offline   Reply With Quote
Old 12-10-2004, 01:39 PM   #8
mdazb
mdazb's Avatar
What's the psi without a reg. (Mech.pump)?
72 C10 SWB 350 Work in progress
98 HD Fatboy
09 HD Heritage Softail
05 Honda Element
mdazb is offline   Reply With Quote
Old 12-10-2004, 01:50 PM   #9
shortymac83
hmm...
shortymac83's Avatar
here's a cheap regulator. Buddy of mine has a 455 that he put in a 81 delta 88 with all of the computer wiring and such, so if you just glance, it looks like a 307. He even reused the 307 mech. pump, but the motor was sucking the float bowl dry. Threw on a Holley Blue back by the tank, and he's still running the mech. pump as well to act as a regulator. No gas problems now. maybe you could do something similar. then you get the amount of gas you need (choose the mech. pump to fit your needs) and always have gas because of the electric pump at the back.
1983 Oldsmobile Delta 88
1967 Chevy C-10 stripper
www.fcrperformance.com - wanna go...faster? talk to FCR.
shortymac83 is offline   Reply With Quote
Old 12-10-2004, 02:17 PM   #10
krazy_texan
krazy_texan's Avatar
could that be part of the reason of my bad gas mileage on my trucks i have been running an edelbrock carb for about 3 years now and seem to have no problem with it.
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 12-10-2004, 02:33 PM   #11
shortymac83
hmm...
what, lack of gas? he was having a problem with the motor stumbling over 5,000 RPM, and running lean and detonating when on the highway for over 20 minutes.
Bad gas mileage is one of 4 things:
really, really bigass gears in the back
really, really bigass motor in the front
really, really heavy right foot
or a poor carb. could either need a rebuild or a simple tune. before I replaced the computer's sensors and rebuilt the carb, I was averaging 9 MPG with a 307 powered delta 88. Did all that stuff, and saw a best ever of 26 mpg on the ohio turnpike 2 summers ago. sits right around 17 mpg, even with my leadfoot.
Old 12-10-2004, 09:38 PM   #12
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
All my trucks run stock mechanical pumps and Edelbrock carbs. Never a regulator and never a problem.
Old 12-10-2004, 09:45 PM   #13
hgs_notes
GEARHEAD
hgs_notes's Avatar
I had to put a regulator in when I was running a holley because the pressure was over about 7 psi off the original mech pump, which I still use. The needle and seat would leak by and flood the bowl until gas was coming out the bowl vent and flooding the engine. Prior to that, I had a spread bore rochester that ran fine on the same pump and same engine. Go figure?
HG
hgs_notes is offline   Reply With Quote
Old 12-11-2004, 03:35 AM   #14
breeh
Recovering 67-72 Addict
breeh's Avatar
On my friend's BBC project we had the same problem. He bought the Edelbrock "matched" components. 850 CFM carb with the Edelbrock fuel pump and the needles were being pushed off of the seats causing it to flood.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 12-11-2004, 08:13 PM   #15
SweetandLong68
Your UncleBen
You are exactly right. I usually set mine at about 4.5psi and that usually works pretty well. But it more depends on your setup.
lata
CHRIS
Old 12-11-2004, 08:53 PM   #16
Bowtiefreak
Some guys say they can run Eddy carbs without regulators and some say they need to run them, both are right, it just depends on your fuel pump. Same goes for Holleys,Demons Q-jets,etc... There are several mechanical pumps out there that really push the 7 psi mark and some that are only around 4-5 psi. The same can be said about electrical versions as well. It just depends on the pump it self. Both Holley and Edlebrock have their fuel pressure specs on their websites (I think) I have plumbed alot of fuel systems in my life and its surprising how much some of the companies differ. Believe me, all fuel pumps and regulators are not built to the same quality.
