Old 12-09-2004, 06:39 PM   #1
gmc67swb
gmc67swb's Avatar
For those of yall with spark boxes....
...where did you mount yours in the engine compartment? I have a 6AL, and was curious where you might have put yours.
thanks,
Larry
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd
gmc67swb is offline   Reply With Quote
Old 12-09-2004, 07:13 PM   #2
Cethern
What was I thinking??
Cethern's Avatar
Box
I mounted my 6a box inside under the glove box I made a mounting plate. I didn't see any place in the engine compartment that I liked.
The only thing I don't like is I can hear the box. If I had a radio maybe I wouldn't.
72 K5 that needs lots of parts..
71 GMC 3/4 4x4 That doesn't need much which is a good thing I don't think I could aford another money pit...
Cethern is offline   Reply With Quote
Old 12-09-2004, 07:23 PM   #3
gmc67swb
gmc67swb's Avatar
How long of a run to your coil? Would this cause any problems if it were too far a run to the coil or pick up?
Thanx for the pics
Larry
Old 12-09-2004, 07:47 PM   #4
Cethern
Cethern's Avatar
I'm running a HEI and got rid of the module for the Box. So ar it runs great 100% better than the points
Old 12-09-2004, 08:36 PM   #5
pissonNOS
senior member
pissonNOS's Avatar
i mounted mine on the inner fender and just used some bushing for mounting it and had to cut it on an angle sorry i dotn ahve any pics i can get some this weekend if you want, and Cethern why didnt you run the box with ur HEI as well?
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 12-09-2004, 08:48 PM   #6
Cethern
Cethern's Avatar
I'am running the MSD 6A box with my HEI, I just took out the 4 pin module.
Old 12-09-2004, 09:22 PM   #7
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
i put mine right up by the battery, then the blaster ss coil on the fire wall, in the second picture, if you follow the coil wire from the dizzy over the heater box the coil is hiding right behind the hood hinge
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 12-10-2004, 06:26 PM   #8
gmc67swb
gmc67swb's Avatar
thanx guys,
Larry
Old 12-10-2004, 06:36 PM   #9
special70gmc
special70gmc's Avatar
on the firewall
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 12-10-2004, 07:25 PM   #10
gmc67swb
gmc67swb's Avatar
I can't tell form the pics, did yall use the vibration dampers?
Old 12-10-2004, 10:14 PM   #11
Cethern
Cethern's Avatar
I didn't the mount I made seems to work pretty good.
Old 12-11-2004, 12:16 AM   #12
71Rat
ran out of money
71Rat's Avatar
i had a mallory box in my engine compartment but for some reason with headers and everything it would get to hot in the engine compartment and the box would cause like a circuit breaker to pop and the truck would shut off..... so now mine is on front of my rad support.... this allows the cool air to blow across it and i havent had a problem yet.... if i drove it more then i would worry about water getting inside of it..... but since mine has been going onto the trailer and down the track then back onto the trailler i am not to concerned..
best of luck
Rat
Modify everything, leave nothing alone!~
71Rat is offline   Reply With Quote
Old 12-11-2004, 02:34 AM   #13
68w/sbc406
68w/sbc406's Avatar
i used them on my coil (cause i had them) but i bought my box used and it didnt have any
Old 12-11-2004, 11:18 AM   #14
Randy70C-10
Randy70C-10's Avatar
Your engine looks great!!
Randy70C-10 is offline   Reply With Quote
Old 12-11-2004, 02:33 PM   #15
68w/sbc406
68w/sbc406's Avatar
thanks, after 7800 daily driver miles in the pacNW it isnt that clean now, just some time, windex, and not driving it all the time its going to look good again
