Garage Queen Material
my truck smokes :(
in the second video, you can see it smoke whenever i rev it up
![]() www.ocbaud.com/videos/idlenew.AVI www.ocbaud.com/videos/revlow.AVI Last edited by ocbaud; 12-09-2004 at 07:56 PM. |
Project92 SWB stepside
Thats called blowby!! when oil blows by the rings!!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
paper or plastic?
ocbaud I've got a killer short block I'll sell you
1967 Chevy SWB 250 http://67-72chevytrucks.com/vboard/s...d.php?t=442157 1977 Chevy SWB 454 No More 454 getting 5.3 http://67-72chevytrucks.com/vboard/s...d.php?t=310518 1977 Stepside Truck of the month winner http://67-72chevytrucks.com/vboard/s...d.php?t=135524 1965 Chevy C10 454 http://67-72chevytrucks.com/vboard/s...d.php?t=731372 1975 Dodge Power Wagon http://67-72chevytrucks.com/vboard/s...=1#post7871388 |
Do you have to add oil very often? From what I could tell it doesn't look that bad. Also, I have a video of my truck if anyone wants to host it.
86 C-10 SWB 2wd -355/TH350, 3:73's (Vin# says its a V6) ![]() Best ET: 13.0 @ 101mph (NA) 11.9 @ 108mph (100 shot) 02 Chevy 2500HD DMax (tow vehicle) 84 GMC Sierra 2500 00 Formula M6 hardtop |
My new 327 was doing something similar, it turned out to be the adjustment of my holley that was causing the proble's. I got it tuned up and havent had any more problems.
Youth soon passes away, but immaturity can last a life time. |
Msybe it needs the patch
my 355 did this when i built it in '98. i didnt have the time, or the money to tear it down and fix it. so i let it go. 7000-8000 miles later, it stopped. someone told me that it was the rings seating against the cylinder bores.
Right turn Clyde
I would try a very complete compression test of the engine. This will tell you a little more about what its doing. I might be over looking it but it doesn't look like much smoke at all to me.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
a compression test won't really tell you anything unless there is a large difference in numbers cylinder to cylinder. you need to do a leakdown test if you want to check the rings.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
Right turn Clyde
Yes I forgot to add the more important of the two tests.
like i said, it only does it while i'm idling and not moving, i've had friends following me and they tell me that they dont see any smoke come out when i get on the gas hard.
whenever it is idling there is small amounts of fuel coming out of the exhaust, the carb is running way rich and will be until christmas when i get my pressure regulator. |
I'm assuming your truck is carbureted?. From the looks of it I'd say it's running a little rich.
#13 | |
the edelbrock carb doesnt like more than 5.5psi MAX at idle and my fuel pump puts out between 6-9 psi at idle. |
#14 |
Blowby would make the tips of your spark plugs oily.
Have you considered buying a pyrometer or egt gauge? Last edited by James670X; 12-10-2004 at 03:17 AM. |
#15 |
all of my plugs looked just like this:
#16 |
thoes plugs look like the motor is rich. from what i can tell from the vid, the smoke is black, not blue. i think you should be fine when you get that fuel pressure regulator. or re jet your carb
Ken Morgan For fun: 1964 Volvo 122 For slow: 1984 Chevrolet C-10 For everything else: 1997 BMW M3 |
#17 | |
i cant ever see the smoke since i'm in the cab with my foot on the gas. the truck smells very rich though. and i wouldnt be able to tell if it was blue or white or what not since i'm color blind ![]() |
#18 |
it most likely does it while your moving too, the smoke just dissipates into the air quickly when the truck is moving. when its stationary like that it just makes it easier to see. it doesn't really look like enough to worry about to me. get your carb dialed in and it might take care of it
#19 |
i have some people on another forum telling me that my plugs look like they are running VERY lean??
#20 |
Lean would be alot more white on the plug.
