Old 12-09-2004, 10:43 PM   #1
longhorn71
longhorn71's Avatar
Suburban Question
I found a 68 GMC suburban3/4ton 4x4.the truck has some rust in the rear fenders and fronts too.the drivetrain is all there,less motor.It was a 350 truck with no other opitons in it.Are they ease to get new sheetmetal for?what is a reasonable price to pay for it?Are they rare?thanks for your help
longhorn71 is offline   Reply With Quote
Old 12-09-2004, 10:52 PM   #2
stevewdale
I recently bought a 71 chevy in about same condition. Front fenders or repair panels should be easy to obtain. Depending on how bad rears are truck repair panels could possibly be made to fit? Oh, I paid $600.00 for chevy. Hope this helps.
stevewdale is offline   Reply With Quote
Old 12-09-2004, 11:37 PM   #3
low burb
Dean, The front sheet-metal is the same as the trucks and the rear patch panels are available from GMC Paul and others. The only patch not here yet is the third door rocker, which should be out any day now. GMC subs are fairly rare. Here is a link showing the number of Chevs made, GMC's were only about a thid of the number. Plus your talking Canada, not many here. Mine came from Cali/Nev. There is a rust free '68 in Fernie in the Trader right now for 25g . However, I don't think you should pay more than a grand for it. I paid 2200 for mine and drove it home from Penhold. I did have to stop in Calgary to change some parts, but after that I drove it for 3 years daily. Mine is a half ton 2wd. Michael
http://67-72chevytrucks.com/vboard/s....php3?t=104816
Michael
1971 GMC Suburban "Crusty"
2000 GMC Sierra 1500 2wd
1978 Scout II
1992 Passat Syncro
low burb is offline   Reply With Quote
Old 12-10-2004, 12:29 AM   #4
longhorn71
longhorn71's Avatar
thanks for the replies.I think i can get it for under 500
Old 12-10-2004, 12:51 AM   #5
sub4rvr
sub4rvr's Avatar
Get it if you can. It's worth saving.
72 C10 Suburban
90 S10
57 F100 (2)
67 Mustang (2)
69 Torino GT
00 Mustang GT Conv.
sub4rvr is offline   Reply With Quote
Old 12-10-2004, 01:20 AM   #6
4x4Poet
Unless the interior is good, I would start at $2-300. The main body "bed" sides are a serious area to have rust. Probably more rust is present. I started to give a tip or two and grew a list. So I'll make it a list.:p
1. The front fenders can be trash since they are easily replaced as bolt on.
2. If you can, take off the interior side panels above the wheel wells. Again, looking from the inside, check for rust at the juncture of the wheel well and the body side.
3. Check for rust in the spare tire wheel well.
4. Get under the Sub and look for tell-tale signs of patch panel work in the floors between the firewall and the wood floor. Some POs use scrap metal for patch work. (I hate POs
5. Check the kick panels all the way down below the mat/carpet.
6. Check the floor under the mat/carpet, especially in front.
7. Check lower rear fenders, fore and aft of the rear tires.
I hope you've found a diamond in the rough.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 12-10-2004, 11:05 AM   #7
All 3/4t4x4s are fairly rare.GMC more so.Check out those production#s.That sounds like a minimal price.Even if the body is too far gone,you can always look for a decent body-donor 2wd.The Suburban frame & drivetrain are worth the $500.The frames are unique.Buy it!
Old 12-10-2004, 12:42 PM   #8
low burb
The only problem with finding a new body is being in Canada. Hopefully it can be saved. Let us know what happens! Michael
Michael
1978 Scout II
1992 Passat Syncro
Old 12-10-2004, 10:52 PM   #9
Canadian694x4
Born To Lose Club
Canadian694x4's Avatar
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Save It...save it for the Suburban Chassis at least. You can always drop on a rust free Cali-body from a more plentiful 2wd burb.
Brian Smith - "Born To Lose"
1969 Chevrolet K10 LWB Fleetside - Proud Owner For 22 Yrs - 1 of 208 Built & Sold In Canada!- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's.
1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 3 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds
2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 17 Yrs- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's.
2008 Yamaha Raptor 700r - Proud Owner For 15 Yrs - ITP Mud Lites.
2015 John Deere 1025R - Proud Owner For 8 Yrs - 24HP Diesel/H120/54D/260B/SB1154.
Canadian694x4 is offline   Reply With Quote
Old 12-11-2004, 03:31 AM   #10
1969 GMC
1969 GMC's Avatar
someone correct me if I am wrong, but I believe the only engine that burb should have had was the 305 V6. The 350 was intro'd in '69...and my TSM says that the 305 V6 and 350 were the only engines for the GMC 3/4 ton 4x4 in '69. But if you could get it cheap, then do it!
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 12-12-2004, 10:36 AM   #11
low burb
Dean, did you buy it? We need more 'Burb members in Canada!
Michael
1978 Scout II
1992 Passat Syncro
Old 12-12-2004, 12:10 PM   #12
BobS
BobS's Avatar
If it originally had a small block then it was either a 307 or 327. I can't find any reference to the V-6 being used in Suburbans or Panels during these years. My book (67-69 Truck Master Parts Book) also show the H-052 as the axle used for burbs in these years when the trucks all used the Spicer (Dana) 60. Kinda odd. In any case, I think $500 is a good price even if the body is rough, those frames don't show up for sale very often.
Bob
V-6....only GMC Trucks have it!
62 GMC W5000 NAPCO-V6
65 GMC 2500 NAPCO Panel-V6
66 GMC 1000-V6
66 GMC 1500-V6
67 GMC K1500-SBC (originally a KM-V6)
68 GMC C1500-V6
68 GMC C1500-V6
68 GMC Suburban C2500
70 Chevy K20-SBC
71 Chevy C30 Longhorn-SBC
72 GMC Suburban C1500-BBC
72 Chevy C10-SBC
72 GMC C5500-ToroFlow Diesel
BobS is offline   Reply With Quote
Old 12-12-2004, 02:12 PM   #13
longhorn71
longhorn71's Avatar
I haven't bought it yet I have to talk the wife into it she says that it is alot of money to spend this close to x-mas
Old 12-12-2004, 03:48 PM   #14
Canadian694x4
Born To Lose Club
Get us Some pics of this rare beast if ya can...
Old 12-17-2004, 01:28 AM   #15
longhorn71
longhorn71's Avatar
Talked to the owner and he is gonna think it over.
