Old 04-08-2002, 03:43 AM   #1
dropped72shortbed
Post
call up summit and order yourself a VPA handle shaving kit for $120. id upgrade from 15lb solenoids to the next up, 25 or 35lb pull.
ive installed this kit on a 64 tempest and two 94+ s10s. comes with everything you need, minus the door filler plates since its obviously a universal kit.
the instructions with the kit are easy to follow. all you need is a little wire crimping set and a drill and your all set to go. can be installed in bout 3 hours.
[This message has been edited by dropped72shortbed (edited April 08, 2002).]
Blake A. - Huntington Beach CA
72 c10 swb
5/5 drop, 350/350, partialy shaved, soon to be 5/7 on 20s.
dropped72shortbed is offline   Reply With Quote
Old 04-09-2002, 08:36 PM   #2
orange72
orange72's Avatar
Post shaved doors
i was wondering if anybody thats done this mod could tell me how they did this..i can do the body work but im not sure on how you install the door poppers and all the other stuff.. any info would be apreciated.thanks.
1972 chevy long bed,sb350 with eldebrock performer intake,crane powermax 288 camand,comp cams 1:5 roller tip rocker arms,hedman headers and 40 series flows . lowered about a 3/4 and all primer
1972 chevy long bed. Currently under construction!! Bagged, 383/700r4.
orange72 is offline   Reply With Quote
