Active Member
Mini Spool
It has been a while since I have been on here and I have a question. Has anyone ran a mini spool on the street? I don't ever plan to put anything in the back of my truck and the truck dosen't weigh much either. My thinking says it shouldn't be too much strain on the drivetrain in turns. Opinoins?
Thanks, Sonny |
its all about the +6 inches
NOT a good idea.
Active Member
One of the mechanics at a speed shop nearby said since the rear of the truck dosn't weigh much, the strain on the axles and such are minimal. He said the inside tire will squeal in tight turns.
Longhorn, WHy not a good idea? My truck is a 68 SWB 350/400 3.73 rearend, 4.2 drop 17" billet specialties wheels on Nitto 450 rubber. Currently rebuilding the front suspension and steering. |
not longhorn..but..besides the obvious safety issues(cornering when wet) and tire wear, the axels can and will break. When this happens(being C clips) it can be deadly. Mini spools are for a dirt track, full spools are strong enuff but he axel issue has to be addressed.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
Exactcy. You WILL break stuff...not a mater of IF...but WHEN.
Spools have no place on the street. |
Maybe i'm stupid, but whats a mini spool??
2014 GMC Yukon XL (Wifey's) 2004 Chevy Silverado Crew Cab Z71 |
17's too small
mini spools are basically axle connectors. you open up your differential and remove the spider gears and put in this mini spool - connector so both sides always turn as one
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows |
Active Member
Advise well taken. I will hold out for a posi or one of those powertrax kits. Thanks for the advise.
