Old 12-10-2004, 02:04 AM   #1
RIDDLA
RIDDLA's Avatar
Help Rearend
Well i keep on breaking my ujoint caps right off it seems to always happen when i stop at a light and i mash the throttle.
What could be the problem?
The truck is a GMC with leaf springs 350 tranny and engine with i think a dana (how can i check?)
Could my rearend be tweaked? Riddla
68 GMC-Stripshow
70 Chevy Monte Carlo
72 Chevy Monte Carlo LOLO
72 Chevy Suburban Blurban
74 Vw Bug
78 Chevy k10 lwb
78 Chevy k10 swb
03 Cadillac Escalade-Duecesix
84 Cadillac Coupe Deville DeElegance
B.O. A Lifestyle Money Cant Buy!
Win,Lose, or Tie
I'm a Raider till i die
RIDDLA is offline   Reply With Quote
Old 12-10-2004, 07:08 AM   #2
dwaite72lnghrn
It sounds like you are binding the joint. do you have a lift or drop that changed the angle at all? Or could just be the axle windup twisting the springs causing the joint to stress and brake. A ladder bar or strut from axle to the front of the spring should help.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 12-10-2004, 11:25 AM   #3
67ChevyRedneck
67ChevyRedneck's Avatar
There should be a code stamped on your rear axle facing the front of your truck near the top on the passenger side axle tubing. Some are near the pumpkin and some are near the hub. You may need to do some wire brushing. Go to this web page to look up the codes: http://www.gmcpauls.com/67-72_chevy.htm There should be two letters, which are the code, and several numbers. The numbers are simply the date the rear-end was stamped. Also, your glovebox door should list the ratio, but the glovebox door or rearend could have been swapped out. Same question as above, and how much horsepower does your motor have?
67ChevyRedneck is offline   Reply With Quote
Old 12-10-2004, 12:28 PM   #4
RIDDLA
RIDDLA's Avatar
yes i do have a drop on the front
The horsepower i wouldntn know i havent dynoed it i should though ive smoked a nissan z twin turbo with a supra behind it lol before so that an idea i guess
68 GMC-Stripshow
74 Vw Bug
78 Chevy k10 lwb
78 Chevy k10 swb
Win,Lose, or Tie
Old 12-10-2004, 12:30 PM   #5
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
I think it's your Right foot. ( Sorry couldn't resist)
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
" If I knew I was going to live this long I would have taken better care of myself "
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline   Reply With Quote
Old 12-10-2004, 12:32 PM   #6
RIDDLA
RIDDLA's Avatar
Lol It could be size 13s
68 GMC-Stripshow
74 Vw Bug
78 Chevy k10 lwb
78 Chevy k10 swb
Win,Lose, or Tie
Old 12-10-2004, 02:06 PM   #7
stickshift_or_walk
Left Foot Functioning
stickshift_or_walk's Avatar
Is your driveshaft one piece or two?
SSOW
69 C10 (#1 son's ride)
72 C20 (Dad's farm truck)
82 K30 (Ex - brush pumper project)
stickshift_or_walk is offline   Reply With Quote
Old 12-10-2004, 04:09 PM   #8
4x4Poet
Big Fat Guess: Sounds like you're running high hp thru a driveline with only 1310 size yokes. You might have a driveshaft shop evaluate the strength of your yokes against your hp/torque. They might recommend upgrading to 1350 yokes. If a 2wd w/coils, perhaps poly trailing arm bushings would help stablize the rear suspension. Check the tightness of the u-bolts. Just conjecture, really.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 12-11-2004, 03:07 PM   #9
RIDDLA
RIDDLA's Avatar
Its a one piece driveshaft i twisted a lite weight one i had before now its a caprice driveshaft
68 GMC-Stripshow
74 Vw Bug
78 Chevy k10 lwb
78 Chevy k10 swb
Win,Lose, or Tie
