12-10-2004, 12:52 PM | #1 |
OBS guy
38's work temporarily with 7 inches of lift?
You guys think I could stuff 38x15.5s on 16x10s with 3" body + 4" suspension for STREET driving only for a little while? The rear isn't the question here, just the front and steering clearance in particular.
I am thinking if I take it easy, and am very careful around turns and driveways I may be able to pull it off. Maybe for one month max, and only driving like 5 miles a week on city streets (rest highway) until I can get my springs on.
88 Suburban Goodies- Alpine, Auto Meter, BDS, Bilstein, B&M, BFG, Borgeson, Bushwhacker, Cowl hood, Flowmaster, Genuine Gear, Holley, Infinity, JVC, K&N, MB Wheels, MSD, Pioneer, Skyjacker, Sony, Thorley, Walker + more |
12-10-2004, 01:06 PM | #2 |
user # 2756
Why not, you just have to know your limitations. The 35s on my GMC will rub every now and then, just have to know when and adapt.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
12-10-2004, 08:48 PM | #3 |
i dont think so. i have 38s 12.5 superswampers on my 3/4 ton with a 6 in lift. i had to cut the fenders waayyy out just to drive it. you can buy shackle extensions at autozone for 30 bucks and give you another 2"in in the front. if you dont mind doing a little fender cutting, you dont need anything.no problem. i am almost positive the will not fit on a 7in lift with out modifications even if your a carefull driver, they will chew the fenders off . i cant even dissconect my swaybar when offroading......rat
12-10-2004, 09:06 PM | #4 |
OBS guy
I don't need to do shackle extensions- I have brand new 6" springs sitting right here. I just don't have the time to install everything in one shot... Want to spread the work
12-10-2004, 09:45 PM | #5 |
The Blazer King
You'd be pushing it.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest. |
12-10-2004, 10:42 PM | #6 |
You'll be fine. I have done and drove my truck for two years with that set up. I had 15x12in rims and 38.5x15x15.5 Gumbo Monster Mudders
12-11-2004, 08:10 AM | #7 |
Shackle extensions only give you half of the lift that the length difference will be. They will change your caster and pinion angles and are just technology (and I use that term loosely) Don't do it
