Old 12-10-2004, 03:14 PM   #1
Jimbotronics
YA YA
Jimbotronics's Avatar
Help - trying to locate thread on installing drop springs..
I don't see the back springs being that big of issue but could use some information on the right way to do the front.
Jimbo
'72 SWB - 350 (frame-off resto in progress - donations accepted)
'04 Chevy Avalanche
'03 Cadillac CTS (wife's ride)
Restoration progress - http://67-72chevytrucks.com/vboard/s...d.php?t=335707
Jimbotronics is offline   Reply With Quote
Old 12-10-2004, 04:29 PM   #2
Gene
Gene's Avatar
Real simple, put jacks under the frame, another under lower A-arm, remove wheel, take the bottom bolt out of the shock absorber, loosen castle nut on lower ball joint(about 3 or 4 threads) and pop the ball joint loose, after it pops, remove the castle nut and then lower the bottom A-arm until the spring drops. Then reverse this procedure for the install. After both sides are done, you creep to the alignment shop.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 12-10-2004, 05:51 PM   #3
greasemonkey
greasemonkey's Avatar
Or you can support the truck, stick a jack under the lower control arm shafts and unbolt the ubolts holding them on. Lower the jack and pull the spring out. I found this way easier.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 12-10-2004, 06:26 PM   #4
72CSTC5
72CSTC5's Avatar
Either way, make sure you truck is high enough off of the ground so that you have room for the lower control arm to swing down out of the way so you will have ample room to take the spring out and the new one back in. I made this mistake several year ago when I was just a teenager and what a pain in the butt if you only have one jack to work with.
72CSTC5 is offline   Reply With Quote
