12-10-2004, 11:07 PM | #1 |
Best Kit for Disc Brakes
Looking for opinions on the best (affordable yet reliable) kit for disc brakes.
Thanks! Douglas
-1968 Chevy SWB = Frame Off/383/Muncie Car 4 speed -1968 Chevy SWB = numbers matching 307/Truck 4 speed. -1966 Chevy II = 2 door No Post/130,000 Orig miles/230 6cyl/powerglide/Vintage AC -1972 Chevy Nova = 2 door/412 Small Block -1927 Ford Roadster = Homebuilt/widened 8"/350/ Custom Everything. |
12-10-2004, 11:58 PM | #2 |
new parts or used?If you go used 71-87 truck stuff will work.you will need to change your ball joints to the newer ones.This swap is cheap and easy.look in faq board for all the details.
12-11-2004, 02:53 AM | #3 |
Got Light Emitting Diode?
i am going the used route, got my full front crossmember for free, and have 550 into brake hoses, ball joints, tie rods, and 6 lug rotors(didnt want to change to 5 lug)
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
12-11-2004, 03:15 AM | #4 |
I used front end from 1975 GMC and it works great. Wasn't too bad of price since 1970's trucks are all over the boneyards.
"You can take the man out of PA, but you can't take PA out of the man" |
12-11-2004, 04:20 AM | #5 |
Define affordable. If you're asking that, than the OEM stuff will be the way you'll want to go. Want better? Then look at the Baer or Wilwood stuff. My preference is for Baer but they are both good. You'll be looking at a starting price of at least $1000 for a front kit. Price dependent on options of course. Even a kit from MP Brakes with 2 1/2" drop spindles will run you $1100.
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc |
12-12-2004, 01:47 PM | #6 |
I'm talking brand new, a whole kit (hoses/calipers/6 lug rotors/pads/master cylinder/booster/prop. valve/stock spindle) which manufacturer is everyone using? Thanks
Douglas.
12-12-2004, 01:49 PM | #7 |
a lot of guys are going the ECE way
12-12-2004, 07:47 PM | #8 |
Classic Performance Products. Great kit, quality, pricing.
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
12-12-2004, 07:57 PM | #9 |
I got my kit through GMCPAULS and it was great to put on, everything you needed. One of the easiest installs I have done.
64 Panel Rebuild Pics Clutch Replacement and Borg Warner T10 Trans Rebuild 64 Panel 1/2 Ton 350cubes/400hp BorgWarner t-10 3:73 Auburn Posi |
12-12-2004, 10:28 PM | #10 |
CPP is the way to go.
I have done a good deal of shopping on this very topic and CPP
has had the best price every time. I have their 5 lug front disc kit waiting to be installed on my 70 right now and a little later I will probably purchase their rear wheel disc kit. Right now their shipping dept. is 5 days behind, but they have been very prompt with my 2 previous orders.
ongoing 1970 c 10 lwb 1994 z-28 few mods.-owned since new 1978 vette silver/grey 25th anniv. paint |
12-13-2004, 12:23 AM | #11 |
Just my biased opinion, I did the salvage yard approach with a 75 front end, but I like ECE. About every 3rd call I talk to Dave. I just like that.
http://home.comcast.net/~r.landrum/w...tos.html-.html '68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades. |
12-13-2004, 01:34 PM | #12 |
I used a yard set-up from a 71 GMC. Got it all plus the power booster, proportioning valve and brake lines for $150. I pressurewashed and sanded everything then painted it black. I spent about $300 more on new rotors, calipers, ball joints, bearings, bushings, tie rods, brake hoses etc.... Don't recall the prices, but I think it saved me a lot of money over a kit, especially with the power booster....but if you want drop spindles, a kit is the way to go......
12-13-2004, 03:05 PM | #13 |
I narrowed my choices to CPP and ECE, and after talking to both at length, I went with ECE. I didn't like the fact that CPP's kit made you change the ball joints, and it didn't come with everything. I would have still needed to buy the master cylinder and prop valve and dust shields separately, which made it more than ECE's kit. Plus, all of the parts in the ECE kit were name brand, and the guy from CPP wouldn't even tell me who made their stuff.
I couldn't be happier with my truck, the brakes work better than i ever thought possible. |
