12-11-2004, 03:04 AM | #1 |
speedometer question
I have a 83 C20 originally a 4 spd that I put on a 70's frame with 79 203 transfercase and 3:42-1 axle ratios that all came from the same suburban. My question is the suburban had a 85 mph speedo and my 83 has a 85 mph speedo but the speed shown is 10 mph slower than what i am actually running. Is there a difference between these speedos that is causing the problem or what. I asked the guy I got the burb from and he said the transfer and axles were original to the burb. And I am running the same engine tranny combo that the burb had too 350/350/203. He also said that to his kinowledge the speedo was right in the burb. He bought it new and is a GM mechanic so he performed any maintenance that it may have needed. But never changed anything related to speedo on it. I am guessing the prob is my truck speedo but not sure. Thanks for any help, its just aggravating at times.
New daily driver 96 Chevy K3500 crew cab dually 53,000 miles 350 Vortec 4L80 Nice ride 67 Chevy C-10 LWB Built 350 TH-400 Wifes ride and family rig: 2001 Furd Expedition 5.4 Liter Kickin back in Rolla,Mo. USA "Do the thing you fear most and the death of fear is certain" Mark Twain |
12-11-2004, 03:19 AM | #2 |
Garage Queen Material
what size tires are you running?
12-11-2004, 03:34 AM | #3 |
Gentleman Jim Driver
It's probably not the speedo, but the drive and driven gears in the tranny don't match the gear ratio in your axle and/or your tire size like Eric said.
You can change the driven gear in your transmission to correct the speedo.
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
12-11-2004, 03:35 AM | #4 |
It was 10mph slow with 31's since I have put 35's on it but I want to get it closer to being right than it is. LOL I know the tire size makes a big difference. So I want to get it close to right for 31's and go from there, I can't afford no fancy custom made speedometer correction dohickey but I have some access to different speedometer drive gears and such. My speedo gear is in the transfercase. I know I can change it but why was it 10 mph off with 31 inch tires. I have run 31's on other 4x's and only been off 3-4 mph. Now I know I am actually off more than 10 mph with the 35's but if I can get it closer to correct for 31's I have a starting place to correct it for the 35's. I am probably confusing the heck out of you guys I am sorry.
New daily driver 96 Chevy K3500 crew cab dually 53,000 miles 350 Vortec 4L80 Nice ride 67 Chevy C-10 LWB Built 350 TH-400 Wifes ride and family rig: 2001 Furd Expedition 5.4 Liter Kickin back in Rolla,Mo. USA "Do the thing you fear most and the death of fear is certain" Mark Twain Last edited by Stano; 12-11-2004 at 03:39 AM. Reason: cause i forgot something |
12-13-2004, 03:01 AM | #5 |
Take your axle ratio & tire diameter to http://novaresource.org/speedo.htm & plug them into the formula, then pick the gear combo that you need. A Chevy dealer should have them.
