Old 12-11-2004, 04:50 PM   #1
smbrouss70
smbrouss70's Avatar
Air Bag Valves
OK, I've decided to piece my airbag system together. I've decided which bags and compressor to use, but I'm undecided on valves. I was wanting to go with manual valves to keep the cost down a little, but companies such as MIC have prices which would make it more cost-effective to go with an electric valve for a 3/8" air line. Basically, I'm asking for help in locating, pricing, and deciding on valves, both manual and electric. I would like to keep it as cost-effective as possible, but still get a good quality as this is my daily driver. Also, I would rather the electric valves so that I don't have to run airlines into my cab, but on the same note I don't want to spend $1000 just on valves.
Thanks in advance
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 12-11-2004, 05:02 PM   #2
Shane
Shane's Avatar
Shop around on Ebay ... you can pick up 4 - 3/8" SMC valves for around $125-$150.
http://cgi.ebay.com/ebaymotors/ws/eB...939782469&rd=1
Shane is offline   Reply With Quote
Old 12-11-2004, 05:15 PM   #3
NotLowerThanMe
NotLowerThanMe's Avatar
Well for a 3/8" electric valve. You shouldn't spend more than $40 a valve.
I've used pretty much every valve out there. SMC, GC, E Air, Parker, Airlift,etc....
I personally like the E (extreme) air valves or GC valves 250psi model.
Both go for $35.00 a piece. There a pretty fast valve for only having a 3/8" port.
Smc valves are also work really good. So it just comes to picking one. I know that E air valves are nitrogen cycle tested and if you have a problem Jim will replace them no questions asked.
Hope that helps.
Nic
www.crazytalkcustoms.com
NotLowerThanMe is offline   Reply With Quote
Old 12-11-2004, 07:57 PM   #4
ZZ4Blazer
Jasons got pretty good deals on electric vavles.
http://www.*****************/products/valves.htm
ZZ4Blazer is offline   Reply With Quote
Old 12-11-2004, 10:49 PM   #5
MP4/8
Run electric valves over the manuals. You will be so much happier. Not to mention the install is a lot easier without having to run all thos lines in the cab.
MP4/8 is offline   Reply With Quote
Old 12-12-2004, 12:41 AM   #6
TheFabShop
Nic is right the extreme valves or the 250 gc are both great budget valves.
TheFabShop is offline   Reply With Quote
Old 12-12-2004, 09:46 AM   #7
smbrouss70
smbrouss70's Avatar
Thanks Guys, you have been more than helpfull... as always.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 12-12-2004, 11:14 PM   #8
NO LONGER DISTURBED KONCEPTZ
NO LONGER DISTURBED KONCEPTZ's Avatar
I sell the Extreme 450 and 250 valves and the GC valves both 1/2" ports. I sell the 450's for 55.00 each, the 250's for 40.00 each, the GC 450's for 65.00 and the GC 250's for 40.00. And shipping is free.
NO LONGER DISTURBED KONCEPTZ is offline   Reply With Quote
Old 12-13-2004, 03:57 PM   #9
bagged72blaz
Got L.E.D.s
bagged72blaz's Avatar
I seen a add in Truckin Godfather Customs, 3/8 valves for 29.00 and 1/2 for 39.00 Black Max 300 psi.
bagged72blaz is offline   Reply With Quote
