Old 12-11-2004, 09:26 PM   #1
shortymac83
hmm...
shortymac83's Avatar
build me a stump puller
Since I'm going to be completely restoring this truck, I figure, why not go with a hot motor to give it something a bit different? I want to keep the 250 in there, but I'd like to see 200 RWHP and over 300 lb-ft. is this unreasonable for a street motor? I'd like to see the torque as low as possible. Granted, it won't be a daily driver, but I'd like to be able to get it on the highway and see 2500-3000 miles a year on this. Just for the heck of it, let's put a ceiling of $5,000 on this. Stock block and crank would be preferable, but the sky's the limit when it comes to camshafts and compression. Granted, it'll have a 4bbl carb and long tube headers, but I don't know what kind of cam or what kind of compression it should use. Also, if it's going to be built like this, what kind of electric ignition should I use? I'd like to use a quadrajet for the carb, with a 1" tall adapter on a squarebore offy intake. The reason for the qjet is its efficient fuel metering coupled to the HUGE secondaries and balls out 750 cfm performance.
A bit about the vehicle overall: truck is a 67 C10 with no options, so vacuum is not an issue, nor is any accessory driven stuff, because PS isn't there to worry about. Exhaust will be straight pipes with no mufflers. If it DOES have muffs, it'll be getting either bassani or flowmaster mufflers. Transmission will be a 3 speed manual, and the rearend will be the stock 10 bolt with 3.08 or 3.23 gears. This truck needs to be able to be cold started in the winter (should we ever need to move it), and it should be able to idle all day in traffic at under 200*.
This is a very long term project (the body and suspension is getting done first, then the motor), but I want to get something on paper so I have a plan and can start collecting parts now.
1983 Oldsmobile Delta 88
1967 Chevy C-10 stripper
www.fcrperformance.com - wanna go...faster? talk to FCR.
shortymac83 is offline   Reply With Quote
Old 12-11-2004, 10:27 PM   #2
70 shorty
Where's my beer?
70 shorty's Avatar
Well, mine is a 250 with a Clifford intake, Holley 390, RV cam, header and hogged out cylinder head. It's also a 3spd on the floor with a 3.73 rear. I'll let you know how it runs when I get it sorted out. I just got it running good enough to move under it's own power today and now need to get it sorted through so it runs good.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam.
79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam.
'03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great
'08 Tahoe LTZ 4x4 155K
70 shorty is offline   Reply With Quote
Old 12-11-2004, 10:43 PM   #3
shortymac83
hmm...
how big is your cam?
Old 12-11-2004, 10:44 PM   #4
shortymac83
hmm...
oh yeah, and before I forget, how much power can a 3 on the tree take in stock form?
Old 12-12-2004, 09:13 AM   #5
70 shorty
Where's my beer?
70 shorty's Avatar
Shorty, I don't know many specifics on anything on the engine. My uncle built it when it was his truck. All I know is he told me it was a mild cam. I still need to find out what kind of compression it's running, I do know he built it as a street truck, it was supposed to be my cousin's high school and college ride.
Old 12-12-2004, 10:10 AM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
If you want bottom end torque, spend a few hundred bucks to get a 292 to start with. That way you still get your inline 6 fix. The 292 is a torque monster. I have one that came out of a dump truck. The guy used to drive the dump truck loaded with dirt, and pull a backhoe with it. That's plenty of torque there.
Old 12-12-2004, 02:32 PM   #7
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
i agree, start out with a 292
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 12-12-2004, 02:34 PM   #8
shortymac83
hmm...
I think I"m being misunderstood here...
Once done, this truck isn't doing any work. It's just going to be a nice street/show truck, and it would be nice to be able to do a burnout every once in a while, and to be able to keep up with traffic with 3.08 gears over 70 mph. I don't need a 292 for that.
Old 12-12-2004, 03:26 PM   #9
Yeah I misunderstood when first reading it also. Didn't think you were going to pull nothing with a 3:08. I may be looking at doing my 250 up in the future, but I do know it'll cost you a fair bit more than building a small block, but it is different and a built striaght six has a wicked sound to it!!
Old 12-12-2004, 03:30 PM   #10
Tx Firefighter
Hey man, you said, "Build me a stump puller" and "I'd like to see the torque as low as possible". All that equates to a 292.
Pistons, cams, intakes and exhausts all cost the same for the 292. The only difference is buying a 292 core to start with. A hot 250 will still pale compared to a 292.
You need to buy Leo Santucci's book on hot rodding 6 cylinders. It's well worth the money.
Old 12-13-2004, 01:00 AM   #11
4x4Poet
Originally Posted by shortymac83
...I want to keep the 250 in there, but I'd like to see 200 RWHP and over 300 lb-ft. is this unreasonable for a street motor? I'd like to see the torque as low as possible....let's put a ceiling of $5,000 on this. Stock block and crank would be preferable, but the sky's the limit when it comes to camshafts and compression. Granted, it'll have a 4bbl carb and long tube headers, but I don't know what kind of cam or what kind of compression it should use....I'd like to use a quadrajet for the carb, with a 1" tall adapter on a squarebore offy intake. The reason for the qjet is its efficient fuel metering coupled to the HUGE secondaries and balls out 750 cfm performance.
...Exhaust will be straight pipes with no mufflers. If it DOES have muffs, it'll be getting either bassani or flowmaster mufflers....
Yeah, you did make a boo boo saying "stump puller" when you aren't starting with enough CIs. No biggie. Going for low-rpm peak torque is still a good idea.
One of America's 6-cylinder experts is Clifford Performance in Temecula, CA (SoCal). Clifford specializes in wringing power out of 6-cylinders. Clifford has reworked countless sixes into far stronger engines than stock. They do it mostly with porting, bigger valves, higher compression, better intakes, and headers all matched well and packaged with balancing and blueprinting to protect high rpm use. Clifford can fuel inject some sixes. Click on "engine parts," then "Chevy," then "250." You definately need their catalog.
For muffs, I recommend SpinTech Mufflers. They are all-welded 3/16" plate with internal "spin traps" that create a vortex with a venturi effect that scavanges the gases out the other end. They have solved the age-old problem of needing low back-pressure with quiet sound. They have quiet street muffs, performance muffs, and also sub-90db full-on race muffs that perform better than straight pipes. Can't say enough about them until you see the price tag. Available in SS and aluminized.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 12-13-2004, 01:20 AM   #12
shortymac83
hmm...
I'll use clifford only as a last resort. I'll be damned if I pay their prices, they're almost as bad as Mondello and Olds Performance Products. "here, buy these AC spark plugs at $25 a piece, because we sell them." I got plenty of power out of our 258 AMC just with head porting, 9.5:1 compression and a quadrajet sitting on an offy 4bbl squarebore intake that I got at a swap meet for $50. Go to clifford, it'd be $1500 or more for all that crap. no thanks.
and if the old man can get 13's out of a 4 door 62 bel air with a 10:1 compression 235 with a 3/4 race cam, a 3 on the tree and 4.11's in the rearend, I think I can get my goal with this motor.
my main question is (and always was) - what camshaft will get me 200 hp and 250-300 lb-ft torque with 9.5:1 compression, port and polish on the stock head and a .060 overbore breathing through a 750 cfm quadrajet with a 1" spacer?
Old 12-13-2004, 01:54 PM   #13
browndawg71
Sounds like you want a tow truck one minute and a dragster the next. scrap the sixes and throw in a 454. that way you will have both.
every man must believe in something, i believe ill have another beer!
browndawg71 is offline   Reply With Quote
Old 12-13-2004, 01:55 PM   #14
shortymac83
hmm...
I don't want either. I want a truck that is fast enough to keep up with a ricer (say, 16's) and be able to stay at 70 mph on the highway without worrying about the wind resistance from a brick of a frontend.
and if I go with a V8, it'll get an olds 425.
Old 12-13-2004, 03:58 PM   #15
Tx Firefighter
What kind of a homo runs a 454?
(it's a joke people, he bought my 454 short bed about a month ago, I'm just hacking on him)
Old 12-14-2004, 01:51 PM   #16
browndawg71
the same kind of homo that runs cummins turbo diesels!!!
Old 12-14-2004, 01:51 PM   #17
67ChevyRedneck
67ChevyRedneck's Avatar
Don't go gettin upset at me....but if you want 300hp and 300 ft-lb of torque the quickest and cheapest thing to do is search your local swap sheet for a rebuilt 350...around here they go from $700-$1500 and slap in a cam...that's all you would need to do for that kind of power. Plus, I HAVE smoked rice burners with a 350, 700R4, and 3.73 rearend, 15mpg, AND my truck will EASILY cruise at 80mph, @2400rpm and PASS traffic. I topped her out one day at 109....damned rear-end is too low......just my .02 cents bro.... seems like a lot of work and too much money to put into a six..... I had a stock 250 I-6 in my truck and I could easily smoke the tires. I'd say leave her alone or get a V-8..... "you can't have a tow truck and a drag car"
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-14-2004, 01:53 PM   #18
shortymac83
hmm...
the thing with these trucks is that EVERYONE goes with a V8. I'd like to try something a bit different, and still have some power. Hell, maybe not even "some" power, but interstate cruising would be nice. like I said, if I go with a V8, it's getting a .030 over olds 425, and T5 transmission.
Old 12-14-2004, 02:08 PM   #19
71cadc10
71cadc10's Avatar
If your goal is to be different and have torque, I'd go the v-8 Olds route. With the grunt of the 425 you can run a highway friendly gear 2.7-3 and still have get up and go, and run an inexpensive TH400 setup. That motor will make torque from 2000 on so you can run a nice tight converter, and motor around happily on the street.
that's my v8 biased $.02
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear
71cadc10 is offline   Reply With Quote
Old 12-14-2004, 02:18 PM   #20
shortymac83
hmm...
Let's rephrase this again,
What camshaft should I use in my 250 with a 4 bbl carb, .030 bore, 9.5:1 compression and headers? Rearend is 3.08 posi and the tranny will be a 3 spd manual. Tires are 28" tall, and it will not be hauling anything but my fat butt around.
If this doesn't work, I'll just give up and call FCR.
Old 12-14-2004, 04:17 PM   #21
Tx Firefighter
post your questions over at www.inliners.org for more 6 cylinder dudes to answer. They have a forum board too.
Old 12-14-2004, 06:30 PM   #22
jeffnstef
jeffnstef's Avatar
Might "Stump Puller" be a double meaning for something else !
jeffnstef is offline   Reply With Quote
Old 12-14-2004, 07:11 PM   #23
Shortymac
her is a good article about a be different 6 build. I am sort of using it as a basis for what I want to do with my 70.
http://www.truckworld.com/How-To-Tec...vy-engine.html
One thing, if you are going to tear into the engine to do alot of this, you mihght want to do what that guy did (and TX Firefighter said) is start your rebuild with a 292 block. That extra bit of cubes and the low end the 292 provides makes a BIG difference.
Be different and good luck.
"Keep em Inline!"
Old 12-16-2004, 04:36 AM   #24
4x4Poet
I'm with you, shortymac83, stick with the six. I prefer sixes in both gas and diesel versions for trucks. Preferably big sixes.
Looks like no one here knows which cam for you application. BTW, won't a cam maker have the info you need? Just curious.
