Old 12-12-2004, 12:11 AM   #1
chevykevy
chevykevy's Avatar
Tilt Columns
Hey Guys,
I am considering a tilt column for my 68. I hear alot about the use of Van columns being used as well but I would like to be sure I'm getting a genuine truck column. Are there many alterations needed to use the van column? Will the bracket on the fire wall line up with dimples ? The stock truck column has a couple pieces of metal that act as stops so you can align the length at the firewall bracket and tilt it toward the engine or toward the fender.
chevykevy is offline   Reply With Quote
Old 12-12-2004, 06:35 AM   #2
JimKshortstep4x4
Smile
The shaft length on the van tilts is longer, the neutral safety switch needs to be relocated, and truck style floor and jacket seal need to be installed.
Once the steering shaft extension is adjusted the column installs and clamps up just like the truck column.
JIm
Old 12-12-2004, 12:47 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
you'll have to look at your steering shaft. In mid 86 there was a chainge. If your steering shaft is one solid rod from fire wall to gear box, then you have the early style and you'll need the colapsable intermedeate rod from a late 68 up to 72 truck.
Old 12-12-2004, 02:07 PM   #4
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
Originally Posted by Longhorn Man
..In mid 86 there was a chainge. ...
he ment in mid 68 there was a change from the solid shaft to the colapsible
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 12-12-2004, 03:29 PM   #5
Longhorn Man
dislexia is a hctib
