12-12-2004, 05:35 AM | #1 |
3rd seat
I have a '69 Burb. Does anybody happen to know if 73-80 Burb 3rd seats physically bolt in place on 67-72s? Can somebody please measure the distance between the 2 front mounting bolts? I have only seen the front so far, I haven't seen the back configuration yet.
12-12-2004, 03:19 PM | #2 |
i will go out a measure mine in just a little bit. also i have the 3rd seat out of my 77 suburban that i can sell you for realllllly cheap.
12-16-2004, 10:54 AM | #3 |
Laynlow77, did you ever get the measurements for this??
12-17-2004, 03:27 AM | #4 |
sorry been reallly busy lately. ill get out there and do it for you tomorrow afternoon! if the measurements are right do you need the 3rd seat? because i have one that id let go for realllly cheap. thanks
12-17-2004, 10:42 AM | #5 |
If everything matches up, I would be interested in the seat. Let me know when you can please...
Thanks, Chris |
12-18-2004, 03:21 AM | #6 |
ok i went out and took some measurements. it is 36 1/2 inches wide from center of the bolt holes, and 23 inches from front bolt hole to back. they seats are adjustable an inch or 2 if yours is a little different. also i dont see why you cant just change the bolt holes if its a little different! ill double check my measurements in the morning. thanks
12-20-2004, 05:34 PM | #7 |
is that seat gonna work for you?
12-20-2004, 08:27 PM | #8 |
I haven't had a chance to check yet. I probably won't for a couple of days. I will let you know either way...
Chris |
12-24-2004, 09:37 PM | #9 |
bump!
12-25-2004, 10:09 AM | #10 |
I should be able to check it tomorrow....Believe me, I haven't forgotten...
Chris |
12-27-2004, 03:15 PM | #11 |
I checked my bolt hole locations yesterday. The two front holes are moveable. They use plates underneath the floor. The back holes are not. They mount to a crossmember. One set is 45" apart. Another set is 32 1/2" apart. And another set is 15" apart. Do your rear brackets match any of these measurements??
12-27-2004, 07:15 PM | #12 |
ill hop in there and check them later tonight. ill get back to you later today or tomorrow
01-05-2005, 03:22 AM | #13 |
sorry man but i dont think that the seat is gonna line up with those bolt holes. how far apart are the wheel wells because you could always just make your own holes. id sell it for practically nothing because its just taking up space in my garage. thanks
01-05-2005, 10:43 AM | #14 |
Thanks for the checking and the offer, but I should be getting another seat here shortly...Again thanks for everything tho...
Chris |
