Old 12-12-2004, 02:44 PM   #1
toddtheodd
The oddest Todd around
toddtheodd's Avatar
Motor Mounts
Ok, so I changed my motor mounts on my truck since the old ones were pretty much destroyed. And while changing the motor mounts I learned that they are a pain in the @$$ to get to.
So my question is this;
Can I changeover the motor mounts to the "through bolt" type of motor mounts? What all is required to do this changeover? Will I need different stands for the frame/crossmember? I'm figuring that it would bolt right up to the block no problem.
Todd
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan
IIOY???
toddtheodd is offline   Reply With Quote
Old 12-12-2004, 03:09 PM   #2
rodnok1
rodnok1's Avatar
Several board members have done this conversion, there are different clamshells and I do believe diff stands are required also. try a search for motor mount change.
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
Old 12-12-2004, 03:44 PM   #3
toddtheodd
toddtheodd's Avatar
Well I did a search, and I did find these... I am looking for something a little cheaper though, which is why I was thinking of the clam shells.
Todd
IIOY???
Old 12-12-2004, 04:12 PM   #4
rodnok1
rodnok1's Avatar
Did you search the board?? try this http://207.44.196.117/vboard/showthr...ight=clamshell
I searched for clamshell
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
Old 12-12-2004, 04:42 PM   #5
NO LONGER DISTURBED KONCEPTZ
NO LONGER DISTURBED KONCEPTZ's Avatar
Well You can go with the 71-72 Big Block motor mount set up and you just need the clam shell and the frame bracket. Also, you can use the 73-87 style with the same parts but the motor will be moved the the firewall by about an inch.
NO LONGER DISTURBED KONCEPTZ is offline   Reply With Quote
Old 12-12-2004, 04:49 PM   #6
toddtheodd
toddtheodd's Avatar
Ah ha!
Did he ever figure out what the exact part # was?
Todd
IIOY???
